OK. Did you get the replacement diode from a reputable distributor?
Does it have the correct markings for a 5.1v Zener?
Bridge across D716? As in remove the diode and put a jumper or read across?
If it’s reading across, 13.37 reading from input D716 and output D712 (13.37v is source as well)
For D712 (or an equivalent diode that you purchased), ground the anode, Connect the cathode (striped end) to the resistor. Connect the free end of the 47k resistor to the 12v terminal of the power supply. What's the DCV directly across the diode?
^^^ This must be done with the diode out of the circuit.
Absolutely do NOT power the head unit up with the diode out of the circuit.
- General Interest
- Car Audio
- Aiwa CDC-MP32 Headunit Unresponsive
