AFOM: An attempt at an objective assessment of overall amplifier quality
Clipping is an abnormal event and should not be a part of the AFOM I think.
Shorting the output is also an abnormal event. Should we therefore not concern ourselves how an amplifier behaves when this happens?
Clipping recovery tells a lot about the effort that has gone into it by the designer - and it’s important that it behaves well as it recovers.
Reactions: Aridace
Having been a part of a number of standards committees, I have one suggestion to offer to perhaps quell the dissent re: "ratings".
Consider not worrying about a "total" rating. Certain people do value certain characteristics above others, and their decisions are theirs to make based upon the criteria they value most.
Although a "spider / radar chart" can be a bit busy with 10 or so factors, to me, it seems a nice choice for this application if people would like to compare properties across amplifiers for multiple criteria. The scaling looks better if the minimum is 1 vs. 0 (just makes things easier to view), but that's not particularly relevant at this point.
Then... the discussion of which amplifier is "better" "in total" could perhaps be put to rest...
Example below....
Very nice!
You might be surprised, some of us do such tests 🙂. The results are of course unpopular, FR deviations are really the only important point, distortion is pointless unless it reaches enormous values. It is unpopular for audiophiles and DIYers as well. The test must be level matched, with no clipping of course.
Frequency response to bench test resistor or real speaker? I think there is difference. Especially with certain class of amplifiers with low damping or current source.
Every time i swap amp or preamp, i do eq flat in listening position. That way i eliminate this, and of course correct the room modes.
I am listening to the 'tone' of amplifier. Not frequency response deviations.
Reactions: Freedom666
I have been thinking about an amplifier figure of merit aka AFOM. Unfortunately, assessing amplifiers objectively appears to have gravitated just one parameter: THD. I would argue this is as bad as the subjectivists who have thrown measurements out of the window. We now have a situation where a very suboptimal amplifier in most of the categories detailed below would be assessed as very good because it measured well on just THD.
I would be interested to get your views on what should be included and what not be included. Ideally, one would want to limit the rating categories to at most 10 items otherwise it would quickly get unwieldy. For example, PRaT would not be a thing in the proposed AFOM and neither would 'airy highs due to using zero feedback'.
So, I'll give it a first cut below, and then depending on how the discussion goes, the ratings can be changed or adjusted so that hopefully we end up with a system that objectively assesses amplifier performance holistically rather than just the dreaded 100 ppb distortion simulation result or THD measurements alone that ultimately mean nothing. I look forward to your comments.
AFOM Objective: -
A simple set of assessment criteria that objectively ranks amplifier performance so that in an ideal case, a higher-ranking amplifier would score well on measurement and on DBT. The target demographic is home audio, driving loudspeakers in the 83-105 dB sensitivity range with an impedance rating of 2 – 8 Ohms.
How the scoring would work. Individual amplifier assessment categories are marked out of 0 to 5 points. No category can have more than 5 points. The higher the score, the better the amplifier rating. The completed assessment will be normalized to a score out of 100.
1. For every 10 W above a 10 W baseline, add 1 point. An amplifier rated at 50W or more into 8 Ohms would therefore get 5 points and an amplifier rated at 10 W get 1 point. Amplifiers below 10W output would get 0 points. This metric weights the amplifier towards 50W and up because that is where you need to be to drive most modern speakers in a domestic environment. Clearly, esoteric 5 or 10 Watt 'gentlemens club' amps costing $19 000 would be penalized.
2. Slew rate assessment is removed. This covered by the IMD test in #6
3. Capacitive load drive capability. Amplifier tested over a range of capacitive loads to assess feedback loop stability. Amplifiers showing no overshoot or oscillation get 5 points. Amplifiers showing overshoot but no oscillltion get 3 points. Amplifiers showing oscillation get 0 points. Proposed test capacitances are 10nF, 50nF, 100nF, 220 nF, 470nF, 1uF, 2.2uF in parallel with 2.2 Ohms at a test signal of 10 kHz 3V pk-pk. This assesses the amplifier compensation design.
4. Complex load drive capability - [simulated load to be proposed] - this assesses the amplifier OPS ability to drive large phase angle loads at high powers. The test signal must be 1 kHz
5. THD+N. Add 1 point for every 5 dB improvement over -70 dB. So an amplifier with better -95 dB THD+N at rated power gets 5 points. The test frequency for this measurement is 1 kHz into 8 Ohms
6. IMD 19+20 kHz. 1 point for every 5 dB improvement over -85 dB. So an amplifier that scores -100dB gets 3 points and one at -110dB ets 5 points. The test is conducted at full power into 8 Ohms. This test for HF linearity and slewing behavior, since gross IMD problems are often associated with SID.
7. Mains hum. For every 6dB improvement over -90dBr. Add 1 point. Amplifiers scoring worse than -90 dB get zero points. The amplifier must be driven at full power at 1 kHz for this test into 8 ohms. This assessment tests the attention to layout, PCB design, and wire dressing.
8. Frequency response into a simulated speaker load [to be proposed] 20 Hz to 20 kHz. An amplifier that shows < 0.5 dB ripple or end bandwidth roll-off over the range 20 Hz to 20 kHz gets 5 points. For every 0.2 dB increase in ripple or roll-off, deduct 1 point. Amplifiers showing > 1.5 dB ripple therefore get 0 points. This test i.a.o. looks at amplifier Zout.
9. Speaker and amplifier protection. 2 points for speaker protection; 2 points for amplifier current trip, and 1 point for thermal protection. Note: amplifiers using a relay ot triac + fuse to isolate the speaker get 0 points for speaker protection
10. Overdrive Recovery. The amplifier is 25% overdriven at 10 kHz into an 8 Ohm load and then scored as follows: give 5 points for rail sticking of 1us or less. Deduct 1 point for every 1us additional rail sticking on either + or - waveform tops. So if the top sticks by 2us, that is 2 points off, if the bottom sticks 2 us, that’s another 2 points off; if the total sticking time is >5 us, 0 points; If there is any sign of oscillation or overshoot as the amplifier comes out of clipping, it gets 0 points
11. Cost per Watt output. For every $5/watt output above $30/W, subtract 1 point. This is really aimed at weeding out overpriced ‘bling’ amplifiers This for example, sets the upper price limit for a 100W amp at $3000 – a good example being the Benchmark ABH2 , which would score 4 points. A similarly powered amplifier selling for $9000 would score 0 points, while almost all DIY amps would score 5 points.
Very valiant effort Bonsai, but in the end futile, i am affraid. We will agree to disagree, since everyone has different taste. Just like we each like different cars, vine, or movies, we all look for different sound to please us.
Like bimo or tillerson said, i like to put shades on mona lisa, whatever that means.
I heared quite a number of amplifiers with very low distortion which sounded like crap. Dry, emotionless, fatiguing. THD is irrelevant for me.
I look for lush yet clean sound, which gives chills to my spine when i listen. Certian opera arias brings tears to the eyes and pressure in the chest. If that amp measures bad, who cares. So certain amount of right harmonics it is. Its not easy to achieve, but it happens.
I ignore double blind bs crap. Please spare me of that.
One more thing, there is claim here, that below certain level THD, we do not hear distortion. But i compared dozen opamps in dac, all very low THD, and i could hear differences. Why? Yes, it was not double blind bs. There is more to sound than THD.
It’s not about deciding if an amp is low distortion or not. If you look at what’s being proposed, an amp with 0.5 % distortion can still score quite highly, but an amp featuring 0.0001% (ie 1 ppm) that fails where it counts on other areas wing score as well. It’s about getting balance into amplifier ratings and making sure at the very least, they are well designed and engineered.
I don’t give anyone a hard time for building a 0.5% distortion amp. What I do object to is when either camp claims they have it right and the other is wrong.
Ok, the very last thing, i promise. After this i go away putting shades on mona lisa.
What about bi-amplification. In three systems i use, i have active crossover to split signal (150Hz) for woofers and the top mid/tweeter section. Woofers are powered by either plate amps or any 60+ watts classAB i have. Top from 150Hz is powered by small power classA amps, which i rotate occasionaly.
Small classA would likely fail powering big tower power hungry speakers. But it fits perfectly for bi-amp system.
How do you score for that?
Example below....
It seems like you forgot the one thing that actually matters: frequency response (see post #33, https://www.diyaudio.com/community/...overall-amplifier-quality.407222/post-7552542 ). Then again, it's only an example.
You already gave the answer, didn't you? You are probably fooling yourself with your uncontrolled tests.
Then again, it could also be due to intermodulation between all the ultrasonic rubbish coming out of a DAC chip, rubbish that will normally be filtered off before the signal reaches the main amp.
That's the whole point of this thread.
Reactions: Bonsai
It seems like you forgot...
No, I just didn't worry about including it after I'd noticed the omission.
I haven't seen you recommend to remove the remaining factors... 😉
Now you're getting it... But, since it seemed to trouble you enough to type a response... Here ya go. Hope it serves as a better example of the chart type. 🙂
You think right, I measure into resistors, R//C, simulated speaker load and also with real speaker. I also measure an effect of speaker cable to frequency response. It is all about amplifier output complex impedance and amplifier stability. Nothing new here. Speaker cable adds more deviation than the amp with low Zout. Forgive me being brief, I am adding some plots instead.
Measurements:
dummy_load_EPDR2.png aiyima_A250W4R_Z30_freqresp_dummy.png speaker cable effec.png
Simulation (different speaker)
Looking at the frequency response of most speakers makes this a no no and can result in buzzing, uneven response and speaker burnout
Without equalization, current drive is not suitable for loudspeakers designed for voltage drive, but nowadays there are many people here using fancy room equalization tools that could probably correct for the bumps in the response that you get with current drive. Electrodynamic loudspeakers usually distort less with current than with voltage drive. In fact, when driven with voltage at frequencies where the voice coil dominates the impedance (anywhere except near resonance), the voltage gets converted into a current by the nonlinear voice coil impedance and that distorted and compressed current then drives the loudspeaker. (Then again, if you want low distortion, you are probably better off with an electrostatic loudspeaker, the step-up transformer of which needs to be driven from a low impedance for minimum distortion.)
Back on topic: for current output amplifiers, I think test 8 should measure the response of the amplifier output current with an emulated loudspeaker load. It may be less relevant, because you will need equalization anyway.
If you were that misinformed that you used it to try to drive big power hungry speakers then it’s hardly the amps fault that you have mismatched it to the load is it?
Most people using small amps pair them with efficient speakers.
As far as scoring goes, you look at the amps specs and measure against that ie it is treated like a black box within the constraints of its spec.
I'm going off topic for a bit.
Is that so?
I believe that when the cone vibrates nonlinearly due to physical factors (for example, when it collapses at the tip of the vibration), the back electromotive force of the voice coil also becomes nonlinear (the back electromotive force decreases), and the flowing current becomes nonlinear (increasing current). I have the impression that this will reduce distortion.
In other words, the core magnetic distortion of the transformer is reduced when driven at low impedance. (I think there was a patent for driving with negative impedance that cancels the winding resistance.) I have a similar image to that, but am I wrong?
I think with burst recovery it is about AC coupling of any kind. DC coupled NC252MP has stellar behaviour in this regard, but has other issues (capacitive load - rise of distortion).
I wish I'd spotted this thread earlier. While I've been guilty of chasing 1ppm 20kHz full power, eg my ravings on ASTX's amp thread, if I was to go back to commercial amp design, my main SQ criteria would be based on some 2 decades of DBLTs .. though only a few intense periods of these were on amps.
On the AC coupling issue, I've ooh'd & ahh'd over this in the past and my present inkling (supported by a few DBLTs) is to limit LF quite severely to have quick recovery. While I don't like my amps to 'block' for usecs as in your test 10, da DBLTs show this is actually innocuous 😱 .. while the msec or greater 'blocking' from assymmetrical overload is certainly audible and alleviated by LF cut. loads of caveats about this including senile memories from a beach bum 🙂
I'll try and post more stuff when I can drag myself from beach bum activities
Reactions: Bonsai and PMA
