AEE Audio transformers
AE Europe is a Dutch transformer producer, the names you see down there are for "triode dick" projects which can nowadays be found on the audio-creative website. From what I know they make some pretty decent transformers and will also do odd requests like winding it with pure silver wire which has been kissed by a virgin
Hello,
Their products are surely nice. I think for things like output transformers you should get the ones that are already used in other designs where they would have had a larger budget to make a few prototypes. If you need a single pair build to your own specs it will be hard for anyone to make a perfect one from the start.
If they know there will be 50 potential customers for a transformer they can make one, check if it works and do some fine tuning if needed.
greetings, Ed
audio amplifier can give very good sound with standard hammond transformer
even in SE
125 gse perfect for 2A3 300B and 6C4C
for hi res and voltage plate load 1629/1638SEA very nice
a bad amplifier sound bad even with gold virgin or trans angel kiss opt
