Adding Balanced Outputs Psuedo or Real?
I made a small line level device with RCA outputs that my brother wants to try out, but he insists I add balanced outputs. He will be plugging it into his new Audio Research Reference preamp and all he uses is balanced cables. The cables are only a few feet long, so I really don't see the point of inverting the unbalanced signal with an op amp or a transformer. Does this make sense or would I be cheating my brother if I just sent a balanced signal through his fancy cables?
balanced audio interface is specifically about balanced Z on the 2 wires, actively driving inverted polarity signal isn't really required, doesn't help with the CMRR of the balanced interconnect except for the 2x larger signal level increasing the S part of S/N
so if you give balanced Zout on the + and - signal, decide what is "correct" in your situation for pin 1/shield (360 chassis connection or RF hybrid, maybe DC ground lifter/loop breaker?), then most of the advantage of "balanced interconnect" would still be there
I see that jensen have changed their site.
They are forcing me to register before I can see the ap note.
Here's 003 from my HDD and a selection of other well worth reading/saving.
  • an003.pdf
  • an001.pdf
  • an004.pdf
  • an002.pdf
  • as001.pdf
  • as002.pdf
  • as005.pdf
  • as003.pdf
  • as010.pdf
