ace3000_1......psx lcd screens?
I'M THINKING OF A VERY BASIC SETUP
something like what's below
would this work for a basic decent projection?
Where is your second fresnell? I don't believe it will work this way. I have used three foil fresnells (f=~310 mm) on top of each other.(it can with two)
The first two on top of each other have a total focal of 155mm (1/2 of 310) an so i can place my lamp at 15,5 cm from the fresnells to get parallel light beams. The thirt wil convert those beams to one point again. The Tft is at 0,5 cm from the last fresnell.
o<||=|>
This is how I put in the tft:
I hope this is of any help.
thanx man, that's exactly what i was looking for........
a pic like that is even better.........just a bracket off the lcd bracket and another piece of wood (or whatever) to hold the board.....
the fresnels that i have are the kind that you get from those ebay rip off deals....they're approx. 8x11 and have the ring grooves on only 1 side.......i think they might actually be two halves.......
i'll finger it out by trial and error.........that's how i'll learn more anywho......
:xeye:
Lowjacker said:
another thing i forgot to ask.....
if i flip the screen over the controller board will be on the top....how do i support it out of the way of the light path?....can you just glue it to the top of the projection case?.....or any other board braced inside?
:xeye:
heya lowjacker,
i got an idea on that cos i have the same issue to solve.
there are holes in the board where the panel was mounted.
take some long nuf brass or ally tubes and screw em on the holes as well as on the ground plate of ur enclosure.
the tubes will not dangling in the light path cos their distance is wider than the screen.
i think that'll work.
heya lowjacker,
things are in progress. last night i made a hack for the scart.
we've discussed it on the german board (thx to futtnik, metallhuhn, motionride, dani).
look the difference from composite to scart (using the rgb).
the one with scart
the one with composite(a/v)
and that's the scematic for the wiring. dani found a method not messing around w switching a 2nd monitor by means of 75ohm resistors and 270 Ohm resistor. so it works with nvidia - cards too.
the pic i got with a simple composite hook-up was really good.......
when i soldered the leads to the inputs it degraded some but i think i might have mis-soldered one and it's not making a direct connection...i think the signal is going through the solder to get to the input......i need to resolder it and try again......
but when i hooked it up with regular little alligator clamps using a composite signal it was a great picture......i'm not sure how it will look when projected but it's good on the screen......
i know the vga is better.......but i don't trust my soldering skills enough to attempt it right now.......
perhaps at another time.......
:xeye:
i got first results w a trial setup this weekend. well, my cam sux..that's why no pics of the pj but some of the setup.
i've put two foil fresnels ea 310mm fl and a cutted glass in the genuine frame of the module the backlight was in formerly.
thats the 70 W HQI TS Lamp w condenser
and that is a result of the german board ( duffy) also from a trial setup.
the diagonal is 60" at a throw of approx. 100" made with the video-in
well, got paid finally and ordered my fans......
now i need to wait and see how things settle after the bills to get my lens......
i can't believe things are going to be so tight that $17 will sway things.....well, it can't rain all the time..........
fans are on the way.....lens will be my last thing to know how long my enclosure will have to be........
then construction begins.......😀
until then...........
:xeye:
yee haw!!!!
my fans came today and they're awesome.....
i placed the two fresnels i have together and came up with what i believe is a 155mm focal length....i got the measurements ready to go and a whole assembley plan in my head......just waiting for the ordering of the projection lens......this really is the suckin' a$$ part.....the damn waiting.......
well, when i get it ordered and it gets here i'll begin construction and be posting pics every step of the way.......
tons of pics to come......hopefully in the near future.....
:xeye:
