Accuphase c200x
hi i have purchased an accuphase c200x amplifier and i had to change all the electrolytic and polyester capacitors.
The line part sounds very good but the phono has a hum which I cannot remove, I have checked the transistors and integrated and it does not go away, someone has happened or can help me. I also look for the service manual which I cannot get .
Cheers
I have no problem reading the PDF which shows a schematic including all the plug-in cards including their circuits with the components shown and parts list .
That is the Accuphase C200X --so whats the problem --can you not access it ?--I can.
If you read the statement above the schematic it says that various small changes were made to the circuit as time went on .
Thats perfectly normal for a company trying to improve its design --that is the 1976 version , the basic circuit should be near the same in that case as they still class it as the same model .
All you need to do is trace the phono circuit looking out for any components used to smooth the power supply to it like old dry electrolytics as the phono section will be the most sensitive.
If the circuit is totally different then somebody has made changes to it unless you can dig up any earlier versions of the schematic which show the difference but the company statement that it is still basically the same model without adding MK #,s to it should mean the changes weren't major.
From the same forum thread where the link was found, Accuphase C200x is a later version that apparently uses IC circuitry, so it won't have the "original" qualities that make the C200 and others desirable to collectors and audiophiles. I think there would also be different power supplies, layout, wiring etc. regardless of whether the circuits are equivalent, perform better or not, quieter, noisier etc.
And to my eyes as well so why say in post #10 --C200 ?
You cant get back to the original problem till till its known for sure if we are ACTUALLY talking about a C-200 not a C-200X and that's your words .
If the different specification are not the same and to reiterate Accuphase says they made minor/small changes in 1976 then what version are we dealing with ?
The download link does not work (adapted to your computer).
So the music is playing, the turntable is in working order and
turntable ground attached ?
Please tell us : hum present without tonearm cable also, with
phono input open and shorted ?
