Accelerometers to measure panel vibrations?
What if you had a mic in front of a full range driver and one very near a side panel and you recorded ( playing music ) them both as stereo - then you played the driver recording ( in both ears with decent headphones ) then the side panel recording, then summed together.
Yes, the idea would be to separate on signal from the other no matter how you do it.
Probably the best thing would be a "balloon" measurement that could be seen in software like Ease. That's common in the pro audio world. You get a measurement of the sound-field all around the speaker that can then be visualized and also used in system/room simulation. You wouldn't exactly know what was what with one balloon measurement, you'd have to make changes to the cabinet and measure again.
As informative as that would be, it would be equally as expensive and time consuming.
Okay, so that was easy. I placed the Dunlavy’s together, hooked one up out of phase, played some correlated pink noise, and wow! It’s so loud! I put my ear up to where the speakers meet, and there’s very little noise. It’s all coming from the panels. As you can see, I covered one up with thick pillows to hopefully keep the lower panel frequencies from canceling out the other side. My wife is using the kitchen(bull in a China shop) so no useful measurements today, but it should be a piece of cake when I eventually run some sweeps.
Okay, finally a few measurements..
The first image is on axis at 10 cm
The second image is the side panel at 10cm
The relative amplitude is much closer than I could have imagined. Yikes!
Compare to John Atkinson's accelerometer measurements..
https://www.stereophile.com/images/archivesart/1294SCIfig12.jpg
The lower side panel frequencies are very surprising. These speakers are stuffed all the way with acoustic foam, but I'll try to see if they have any bracing at all.
The side panel resonance measurements by John Atkinson line up perfectly with my acoustic measurements in the 500 to 750hz range, so the comparison there can be confirmed as pretty much valid. In that area, it's only about 10db down from the reference.
Yes, the mic is calibrated(Umik-1), but this is a relative comparison at 10cm. I wanted the signal to noise ratio to be as high as possible without clipping the mic. The vibration peak is only at 98db. The loudspeaker on axis is 108db.
Dunlavy midbass, in phase and out of phase. Taken at exact center, between speakers..
No disrespect but have you calibrated the "absolute" loudness of the measurement system (typically using an SPL meter - even a smart-phone app) or only the FR of the mic? As I said, not critical but helpful to see the levels your mic is picking up.
The S/N I meant was speaker/cab ratio. What is that?
B.
what I was expecting is that the best cancellation (between the two out-of-phase drivers) would be at low frequency, and the cancellation would become less effective at higher frequencies.
You are getting about 10 dB of cancellation at 100 Hz, and closer to 20 dB at 200 Hz. By 400 - 700 Hz you are getting 30 to 40 dB of cancellation.
