About VAS and drivers transistors
Hello
Before buying any KSC3503 transistors for Vas, I have a question.
That transistor do have a Ic of 100 ma DC and 7 watt dissipation, is it enough to use it in the Vas for any amp up to 100 watt ?
I would not use it for the driver.
Thank
Bye
Gaetan
It depends on the topology and VAS bias current, but it should be OK up to
about 20 mA bias current on +50v/-50v rails. You have to derate the Pd for temperatures higher than 25c and use a heatsink, but otherwise it's generally fine - however, you'll probably get better hFE, fT and Cob if you settle for Vceo around 120..200V, rather than the 300V that the KCS3503 is rated for.
> The Sanyo 2SA1477/2SC3787 look pretty good...
>Cob = 3.0 pF
>IC (MAX) = 140 mA
For a VAS, their siblings 2sa1478/2sc3788 are better. Similar,
but with Cob = 2.6/1.7 pF, Vceo=200v, Ic=100 mA, and Ic-Vce
curves that look like a Vernier caliper.
Noise is not usually specified for medium-power devices like these that are used for CRT video drivers, audio VAS, predriver, driver, etc. These aren't exactly small-signal devices that are used at the LTP or front-end for low-level signal amplification, which is where noise is likely to be an issue.
For LTP or general-purpose low-noise pre-amplification, there are a very large number of Japanese small-signal transistors that have an outstanding combination of specifications. Presently, my favourites (for no particular reason other than local availability and price) are:
Toshiba 2sc3112 (fast, extremely low noise, super beta, low Cob)
Toshiba 2sa970/2sc2240
NEC 2sa992/2sc1845
NEC 2sa992/2sc1845
The small-signal transistors like the 2SA970/2SC2240 get their dissipation limits exceeded if I use them in the I/V posted above with a DAC like the AD1955 which puts out a large current. So I need transistors that can handle more power but are still very linear, have similarly high fT, and are low noise enough for an I/V in a 24-bit DAC where I'm aiming for -130 dB THD @ 20 kHz. So, what transistors do I pick?
> which shop in Bangalore do you get these?
Places on S.P. Road to try (I don't remember exactly where I bought
each of these, but these are my sources in decreasing order of
preference):
Chetan Electronics
Darshan Electronics
Swastik Electronics (?)
Om Electronics
Bangalore Electronics
Vishal Electronics
From memory, these are available from about Rs.5 to 7 each.
I don't know about the noise specs, but if hfe clustered at 60 is sufficient for your application, the Fairchild KSC3953 with an fT of 400 MHz and Ic=0.2A might work. It's linear like vernier calipers and cheap as chips.
Edit: added Darshan and changed order of preference.
Hello
I have decide to ad a 11 pf phase lead capacitor to an amp that a friend ask me to modified, I was think to put it between the base of Q2 and the colector of Q6.
Just to be sure, is it the best place for a phase lead capacitor ?
Here is the amp input schematic.
Thank
Bye
Gaetan
AndrewT said:
cap is in the correct place. Allow for a series resistor in case you need to adjust. Or alternatively a parallel R+C to trim the stability/margins.
C8 & 10 might need to be retained but at much lower values.
Hello Andrew
I've found time to do those mods on the amp and a 15pf cap at that place do made the amp to sound better. The amp are a Sima 3050.
Thank
Bye
Gaetan
Hello
My friend want me to modify this amp because the sound of it are a bit harsh and the sound stage not very good.
Thank
Bye
Gaetan
R22 and R28 are center tapped to the output.
This sounds like a bad idea to me, in case the amp runs at rather low bias currents, because this kind of configuration tends to push the (pre-)drivers into Class B at rather low output currents.
Regarding VAS-Transistors in general:
Why should one use a VAS, which is not cascoded ?
In case it is cascoded the feedback capacitance of the VAS transistor turns from a feedback capacitance (often already the dominating pole) into a simple capacitive load for the VAS, just like the (nonlinear) capacitance of the (pre) drivers.
In case a cascode is used for VAS, why then should be a relaxed specification for the predriver's Cob ?? Their feedback capacitances are then a load very comparable to the one of VAS transistor's capacitance !
Conclusio:
For an optimal VAS, running in cascode mode, the predrivers should be the very same type of transistor as the VAS transistors !
On the other hand side:
Is there any proof, that the Cob of conventional VAS transistors does any harm to overall distortion ? I would say, that the load of the VAS always dominates, as long you operate in Class B or Class AB !
