AP System 1 Clone
(From post #46 in this thread:
Dale
Is there any more information available about this project? I tried searching the Forum, and posts from "GK", but didn't find anything.. . . . I’m currently building my own version of the (PC controlled) AP1. However to keep the generators THD as low as possible I’m going to use relays to switch the timing capacitors. For the timing resistances (of the integrators) I’m going to use a dual gang potentiometer. Its shaft will be coupled to a small DC motor via a reduction gearbox.
A uC based frequency meter and servo controller will control all of this, auto tuning the frequency to the desired value.
A Vishay VCR2N "variable resistor” (very linear) will be used in the multiplier for the amplitude control, and modern opamps throughout.
I figured that I can used the quadrature outputs from the intergrators to make a 4-phase rectifier (based on a pair of unity gain inverters and an LM3086 five NPN transistor array – the fifth, substrate connected transistor used for biasing) to keep the AGC loop ripple really low.
Glen
Dale
Glen (GK) is now at Andy's forum, and he just posted there about it probably having seen my posts on computer control and SV oscillators:
State Variable Oscillator
Glen, Andy, and several other top notch engineers have been banned from here; I didn't follow the cause for it all.
Only Andy was banned, wich i desagreed , the others did left voluntarly..Glen (GK) is now at Andy's forum, and he just posted there about it probably having seen my posts on computer control and SV oscillators:
PB2,
I tried to register some time ago at Andy's forum. No answer.
This site seems to be defunct - does anybody know if the content of this particular thread was moved elsewhere?Glen (GK) is now at Andy's forum, and he just posted there about it probably having seen my posts on computer control and SV oscillators:
Dale
Dale
There was some recent (last month, perhaps two) flaming there and Andy put the site on hold. I believe that it will be easy for him to put it back online and I suggested that he at least do it as read only so that those who contibuted have access to their efforts.
Not sure if he ever will which is unfortunate since there was a lot of good information there.
Dale
Glen sent me this link to his projects site where he provides information on his design:
Audio Projects Home
Glens SVO:
http://users.picknowl.com.au/~glenk/uldo.htm
Your religious mission against TPC is inane and it is starting the get rather boring - and you're still banging on about that damn overshoot 🙄
I'm quite aware that NDLF and TMC do not cause overshoot as does TPC and your blanket claim that NDFL does not cause a mid-band phase dip is just nonsense.
I guess you can just disregard all previous analysis of Cherry’s designs, including the phase response I attached again to post 72 in this thread! TMC can also have similar mid-band phase characteristics within the Miller loop.
Dismissing a compensation technique because it causes a mid-band phase dip (overshoot or no overshoot) is just as nonsensical and pseudo-technical as calling an amplifier with an open loop bandwidth of 100Hz slow, IMHO.
True
Edmond is given to making such misleading assertions.
Glen, Andy, and several other top notch engineers have been banned from here.
Mods who throw the baby out with the bath water.....Sad!
- A superior VAS clamp and VAS current limit for the Blameless.
