A powerFULL amplifier named Dirty Harry
Because the big size of the schematic, yet i have not achived to convert this in jpeg to upload. I enclose a photo of this power amplifier module, a photo of the plan, and finally a zip fille with the drawing. May pointed out, that this module has presented already in my previous thread "wow!a beautifull preamplifier module" but for a different reason. Anyhow in this, you can see some oscillograms of his performance.
Here is the zip file, but you need a CAD program to open it because the format is *.dwg created by AutoCAD. Such program except AutoCAD is the Corel Draw. If you can open the drawing, then the image has the better quality.
  • fineal1k - standard.zip
Re: Oh pain...i have not the CAD program...oh pain!
destroyer X said:
It seems to be interesting...very interesting.
Having in PDF, standard adobe files, please, upload it to me:
nanabrother@yahoo.com
regards,
Carlos
Yes shure, this is a good way, with e-mail. I post the plan as soon as possible. Also me i have thinked to break the schematic in 3 parts. But needed to go from the begining.
If you have a CAD/CAE program, as i suppose because i have see your amplifier already, i can mail you the plans in Gerber.ASCII format.
Fotios
Sorry for the confusion, but because I have made this drawing before 5 years, I forgot certain important changes. These are:
R3 = 220R and no 390R consequently tail current from 1,7mA becomes 3,18mA
R4, R17, R15 = 2K2 and no 1K
R11, R16 = 22K and no 33K
R9, R10 = 33R and no 56R consequently each emitter of current mirror has 0,87mA
PR1 = 500R and no 2K because MJE340
R20 = 680R and no 390R
R21 = 470R and no 1K5
Output inductor: 15 turns of copper wire d=2mm/core d=10mm
This moment I search for layout. I will make little time to find it.
Also the PCB is double sided and her back photo is attached.
I remind that in my thread “wow! a wonderful preamplifier module” there are the oscilograms. If you want inform me to transport those in this thread.
For this amplifier, I have also drawn and constructed the following:
Power Supply, Output protection, and finally a dynamic limiter of the input signal. I forgot also to mark the Resistor of input; this is a Log potentiometer of 50KÙ.
Thus the input impedance is about 50KÙ.
To be continued
Fotios
fotios said:
A photo of schematic in order to understand his size and the difficalty to convert it from the original *.edb format to jpeg.
Suggestion: use autocad and do a fake print (a send file to disk, not to a printer). If you use a Scitex or Apple postscript printer drive, you obtain directly a .ps or .eps file that you can easily convert in a pdf format (and usually is directly openable by program similar to Adobe illustrator. The trick often work also outputting "fake" printing from many spice software programs.
Hi
Piercarlo
