holy sh......
really nice Job being done here.....
When you designed this DDDAC, did you ever think it would be modded this far ?
Wow Chanh! Saying another time "great job" would seem banal at this point. I very much like your approach and attitude to make the job done the way it should be. Grand complements for all package!
Btw, what is this incision machine? It looks not so big and make nice job. I'm wondering if is available in europe somwhere. What's the brand and model please?
For the BBB-Hermes-Chronus users.
Found a way to connect the BBB directly to the DAC-Board.
No Mainboard needed any more.
Conversion to Right Justified Dual Mono is done by the botic driver and ALSA.
The sound even improved
If there is some interest I can post how to do this later.
It took some time to get it working, but actually the modifications are quite simple.
Future DDDAC's owner
Hi everyone !
First of all, I would like to thank Doede for sharing his great job and crazy tweaker for their ideas, I a learning a lot of interesting thinks here !
I will order all that I need for build the DDDAC but I have some questions before doing it...
1) Did someone has compared full tweaked single board VS 4 boards with "soft tweaks" (caps, CCS) ? What were the best way ?
2) I would like to create ma Raw PS with Lundahl choke. I'm asking myself why nobody did it with Lundahl LL1638/4H ? Apparently, the main board is 10mA and each DAC module 100mA, if I use 4 modules, the choke will support those 410mA and I can make a LCLC with only 1 choke. No ?
3) I am looking for BElleson regulators. Isn't it possible to use one 5V for the main board, one for Left 8V, one for Left 3.3V, one for right 8V, one for right 3.3V ? If I go with 4 dac modules, if I remove each LF circuit on the modules, isn't possible to share the Belleson suplly ? For example, for the 8V for left side, I connect each DAC module VDD together, will save place and money. BAd idea ?
Thanks for your help !
Julien
Hi everyone !
Julien
Yes please post! Very interested!For the BBB-Hermes-Chronus users.
Yes please post!
Sure, will do! Working on it already.
Chan and Don, great work! Looks really tidy and well thought out. Very hard to get that level of finish. Most impressed
Jptz, yes! I suspected and hoped this approach was possible from a while ago, but never found the time to properly work out how. That's brilliant
Acko confirmed to me a when I was researching it that it's also possible to reclock 2 separate data channels with the s03 with only a slight modification too, but the software config was always the challenge for me.
Looking forward to hearing how you achieved it
James
James
Highly interested!
Can you describe the sound improvements?
dwjames: yes, I think this would work with every reclocker which has at least 2 separate data channels.
Probably it's also possible with a rasberry. But I don't know much about it. It all depends on the driver. Miero did a very good job with the botic!
supersurfer: I think this modification sounds mostly better because without the hardware shift registers, there is less jitter now. (There is maybe also less noise because of one less voltage regulator)
So the improvements are like what you usually get if jitter is reduced, more (micro) details, a bit more bass, darker background, everything just sounds more right.
Did a lot of mods already on my DDDAC (Thanks btw for the things you suggested, tent shunts, choke psu ...) so my system was playing on a good level already.
But now it became even better. Best of all, it's a mod which is easy to try out and costs almost nothing if you own a BBB with an reclocker already
- Digital Line Level
- A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
