A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
actually my next thinking is to use one complete 8-stack for the LEFT channel and another for the Right channel. for true DIY easy to omplement of course as you lead the data Signal to the other side of the stack and the Audio current Output Need to be lead to one (half value) Rload.
Spdif Input and USB Input can be looped through. between Mainboards. and of course two poer supplies. than it become true double mono stereo
Did anyone ever try this? If so what was the impact on SQ?
Dear Doede,
Thx for feedback 😉
But 15 is maximum? Problem: with lipo this is a little bit on the edge in both directions 😉
3 cells have nominal 11.1V but charging end Voltage is ~ 12.5V
4 cells have nominal 14.8 but I think they will have something between 16V and 17V at fully charged.
So... good question what to do 😉
Greetings
Christian
Dear Doede,
Thx for feedback 😉
Greetings
Christian
with 17 volts the 7810 on the DAC board will get a bit warmer, but it will still stay within limits
the 7810 will dissipate ~ 0,7 Watt at 17 volts
according to the datasheet the raise in temperature is 25 degrees per Watt, so it will be ok
Dear Doede,
Thank you for the feedback 😉
"Just in case" i put 2 diodes in series to the battery. This makes sure, that the Coltage will stay below 16v!
Works pretty good... and i don't hear any bad thing about it 😉
Will try to play with some capacitors on the 12v input... will let you know the results 😉
Greetings
Christian
Good idea
Dear Doede,
"Just in case" i put 2 diodes in series to the battery. This makes sure, that the voltage will stay below 16v!
Greetings
Christian
Excellent Idea 😎
I could have done something wrong. But I bought 3 new boards.. Which say 384/24bit I mixed it up with my single board which says 192/24 bit... Now everything sounds 10 times as fast. Voices like chipmunks.
Not sure what you mean, really higher pitch or as way of speaking?
The boards are dac "only" so there is no timing element.
you can send me some more info to my regular mail to go deeper if you want.
I don't know what is your i2s source, but you may have linked a masterclock output (22/24 MHz) to bitclock input (usualy slower than masterclock, 64*Sampling Frequency).
Thanks for assisting. The thing is..nothing changed in that department. I just stacked 3 extra boards on top of each other. But I will check ....
i2s source is hifiberry digi+ pro
