A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Hi guys.
I have finally decide to try out this exiting dac. Can't wait to do a shotout against my Buffalo IIIse dual mono.
After reading a lot of pages the last days, I've decide to go for 4 decks and the Cinemags.
Need answer on a few things that is still not perfectly clear to me.
1. Is it ok to use 33R ( IV resistors on the motherboard ) instead of 34R ? ( 4 decks )
2. Must there bee a resistor between the secondary on the Cinemags (xlr out ) If so,
What value ? Shinkoh Tantalum 2 watt is my choice for the IV resistors. But since they are pricy maybe it's ok to use some Takman carbon or another ok resistor ?
3. Is the hookup-wire between the dac boards included ? If not, what gauge is correct here?
Best " the dancer "
5V Problems
dwjames,
I use a 5V SPM Belleson on the main board which is also providing power to the WaveIO optical isolation chip and main board LEDs. Maybe the load on your Vreg is too low for stable regulation. Try adding a 330 or 470 ohm resistor across the Main board Vreg to raise the load.
Hi guys.
Best " the dancer "
Wish you already good fun with the built 🙂
On your questions,
33 ohm is ok
15 k is recommended, but feel free to just listen and try. It has only to do with transient response
Hook up wire is included.
Separate thread for fully upgrading a single board DAC
Undarra:
Hi Carlsor
Do you think you could summarise the individual mods you have tried and briefly comment on the percieved improvements. It's hard to keep a track of the variety of mods from people as this threads moves so quick!
First - congratulations on your 1/2 clock delay circuit success. That makes 4 out of 4 reporting a major improvement in SQ on red boards.
Yes. I will start a separate thread for fully upgrading a single board DAC and also include some options successfully used by others. I will spell out in complete detail everything I have done. I agree that these upgrades do get scattered in this forum.
I can't wait for the unveiling of Doede's DSD DAC.
Could I get a confirmation that the "dot" on the tent clock is the ground pin? The diagram on Tentlabs is unclear to me. A "dot" on the circuit board would make this a non-issue.
I am pretty sure im right, but there is no confirmation on the DDDAC or Tentlab site. I am sure this common knowledge to most of you, but I don't want to have to unsolder and resolder this expensive part.
As I am not sure the dot is always printed on the same position, I used as indication the only sharp corner of the tent clock. This sharp corner is indicated on the mainboard as well. If you refer to this, you will have no problems....
