Yes, to do this effectively requires analyzing frequency bands individually. That's the only way to maintain fidelity. It'd be best to use continuous wavelet transform. I'm guessing this cannot be done in real time. So it will be a matter of converting 2 channel files into 3 channel files in advance. Or just waiting a while for your song to start. There may be a way to speed it up a lot with minimal noticeable difference.Miraculously, if this mess is played back with "high fidelity" our head/ears can "disassemble" the reproduced-in-room soundwave and (more or less) mistake it for the original live sound. Any effective processor/algorithm will have to preserve the myriad aforementioned relationships in amplitude, time, and linear phase (really linearly-out-of-phase).
That seems very reminisant of the design philosophy behind the Professional Dolby SR noise reduction system for recording 🙂Yes, to do this effectively requires analyzing frequency bands individually. That's the only way to maintain fidelity
Agree, and the creators of these technologies are still being awarded today meaning that all the awards given till date are still not enough for the pathbreaking changes Dolby has brought, especially to the cinema stage, besides their NR tapes. Without Dolby, we would be running mono optical audio with 5kHz bandwidth !!!You've really got to hand it to Dolby Labs. for some pretty amazing technology over the years > spanning all the way from Professional recording to numerous domestic products.
https://news.dolby.com/en-WW/237764...-cannes-marking-50-years-of-dolby-s-work-in-f
And an interesting article
https://www.film-tech.com/warehouse/manuals/dolbychronology.pdf
Dolby Pro-Logic II must have been when some steering was introduced to the rear channels because I know DPL type 1 had no rear steering >
To be clear, DPL had steering between L,C,R and S... but the surround was a single channel. I think you are correct that DPL II added what we had called a split-surround channel... and at some point the rear surrounds got added, bringing the total speakers up from 5.1 to 7.1
Pretty much as the cinema version worked. Because of the way film sound was read off the film, using a slit of light to hit a photo receptor, it was also difficult to ensure minimal phase mis-alignment. The light source went through a slit and lens system and the slightest rotation of the slit caused timing errors (delay) betwen L and R from the projector, before even reaching the electronics of the audio processor.The rear of type 1 was also filtered to a bandwidth of 100Hz to 10Khz
VHS Hi Fi had vastly superior audio performance than any other medium at the time it was introduced, only really bettered by DAT and the ADCs which used VHS as the storage mediums.
I thought that happened automatically, as the surround information was encoded with opposite phases in both channels so that they inherently cancelled each other leaving the sound coming only from behind. And, this surround channel being delayed, did not interfere with the cancellation at the front.
Without more processing, when a surround signal was present the C would be eliminated naturally but L and R were still present and quite audible. Much like what happens when you reverse a single speaker in your home. Many people don't even realize it happened until they wonder what happened to the drums.
My point is there was a lot of subtle decision making that had to be done all in analog using integrators, VCAs and a complex summation before the final signal to each channel was ready.
Even when it all worked perfectly once you heard the level changes occurring you could always pick out what the matrix decoders were doing. While I miss the old days of working in theater sound I am also really happy that modern film music has progressed as much as it has and I no longer hear the DPL steering.
@ASCTim,
I downloaded the free 14-day trial version of the SurCode DPL encoder (version 2.5) and I can confirm that it has a built-in wave file player with DPL & DPL II decoders with both music and movie modes and the steering. Besides, it also supports saving the DPL decoded audio to another wave file and comes with a pdf user manual inside the program folder that explains all the options.
Whatever I tried playing on this sounded good to me and hence the recommendation !!
https://surcode-for-dolby-pro-logic-ii.software.informer.com/2.5/
Also, while I"m at it, I'd like to get on a soap box/rant. The Arcam receiver I use absolutely refuses to do DPL for 2 channel Dolby Digital. Something all my previous processors, including an old Arcam, could do.
For Netflix at least, they encode ALL their video into DD. For 2-channel this disables the center and surrounds, even when the source was a 2 channel Dolby Surround track.
Thanks! I'll play around with that.Whatever I tried playing on this sounded good to me and hence the recommendation !!
- A Hafler inspired solution for the phantom center image problem
