Hafler and matrix surround is bringing back old old memories. I worked near Atlanta at a theater equipment manufacturer and we bought tons of Hafler amp modules. Probably kept them in business for a long while.
We also developed our own Dolby Surround decoder. It was kind of amazing how Dolby's original surround and our updated version worked. None of it had the benefit of DSP technology. I'm not sure what Dolby used but we built our matrix detector using Voltage Controlled Amplifiers (VCA's). Essentially op amps with gain adjusted by a DC voltage. The sums and differences of various inputs would produce varying DC levels to the L, C , R and surround VCAs.
Dolby's matrix steered very hard and as a result lost a lot of ambience. The focus was on effects so not very surprising. It was also noisy as hell, but I digress.
In the lab we had a version which allowed us to turn a pot to adjust how hard the steering would be and I can't tell you how much better softer steering sounded. It still steered but wouldn't kill the side channels as hard.
Anyway, my point is that if the OP wants to experiment with modest steering he'd probably be pleased. Otherwise in the modern world I've found Neo6: Music and movie modes to be outstanding for this type of work.
I'm thinking about trying to cook up my own upmix method using DSP. It's fun to think about ways it could work. Exactly what should it do with signals that are completely out of phase, or partially out of phase? I've got some ideas but have to learn some coding to execute it. At least this way I'll know what's going on and perhaps come to a better understanding of what sounds good to me and what doesn't.We also developed our own Dolby Surround decoder. It was kind of amazing how Dolby's original surround and our updated version worked. None of it had the benefit of DSP technology.
So was the voltage control coming from another channel to create steering? And this was a matrix detector for material already encoded with surround?I'm not sure what Dolby used but we built our matrix detector using Voltage Controlled Amplifiers (VCA's).
So by kill the side channels, you mean pull all of the center channel info completely out of them?I can't tell you how much better softer steering sounded. It still steered but wouldn't kill the side channels as hard.
Hi OP:
Glad you found any of my ramblings interesting. Before going on too much longer I want to give credit to the engineer who actually designed the circuit I'm discussing, Oscar Neundorfer. I only did the PCB design and reverse engineering of the Dolby boards of the time.
Please keep in mind the goal of the matrix decoder was to give everyone in a theater an excellent experience, no matter how far left or right or back they sat.
To answer your questions:
No. Dolby Surround used exclusively 2 channels from which a center and surround signal were derived and from which all 4 were steered. The only case I'm aware of where a separate control channel was used was for Sensurround.
Yes, exactly. A good decoder would perform reasonably well with mono or stereo signals, but also work for those with full 4 channels encoded.
The control signals were used to turn the 4 channels up or down as needed. Lets consider the simple case of the center. It's very simple, it's L + R.
The problem is what do you do when you have a L only signal? That's where the analog logic comes in. It should notice that there's no R at all, or very low level given noise, and essentially shut the C off. It should also be aware when L and R are on but the signals are not highly correlated.
A similar thing happens for Surround, which was L - R (or R-L, can't remember, but not relevant). Any time that L and R are not identical this would produce a signal in the surrounds so the matrix' job was to keep the Surround off until there was an equal and opposite signal in the L and R channels.
Both the Dolby and the other circuit I'm thinking of used a number of derived pseudo channels, fed by VCA from a variety of combinations, and each output op amp would eventually have multiple inputs to sum. If you haven't learned about op amp theory and how to mix multiple signals now is a good time.
There were additional conditions possible than discussed above. For instance, if a strong center was detected, L and R should be suppressed unless L and R had significantly uncorrelated signals. This is where hard steering comes in. Dolby would be ruthless in turning L and R down, while Oscar was showing that being more gentle could really let the sound track breathe and create a more immersive experience.
The hard steering effects of Dolby Surround were the bane of many a movie sound engineer. It took a great deal of control away from them, something that's been completely restored with the advent of Dolby Digital and DTS. 70mm film with discrete magnetic tracks and the very rare 35mm discrete magnetic track films (The Natural) really showcased how limiting Dolby Surround was.
Hope this helps!
Hope this helps!
It may not be possible to apply DPL on the receiver unless it "knows" exactly which channel is which, and is capable of re-mapping appropriately. However, you could apply DPL from the music player itself, before the 3-way crossing split occurs.I'd like to try that but I don't know how to insert the algorithm in to my signal chain yet. I'm using a 7.1 receiver via HDMI input. 6 amp channels are used for stereo with a 3 way active crosssover from my computer.
Just a quick question >
With consumer surround amps & receivers, have they yet gone beyond 7.2 ?
DPL had two modes and I'm not sure which mode you're referring to, ... When I tried DPL cinema mode on music, the steering did work well but I did not use any surround channels (3/0 LCR only). However, tastes change from person to person.. ,Dolby's matrix steered very hard and as a result lost a lot of ambience. The focus was on effects so not very surprising. It was also noisy as hell, but I digress.
Yes. DTS and Dolby Digital (Atmos) have gone to object based sounds. In original DTS/DD with 5.1 for instance, each channel was discretely encoded, and you had perfect separation. However with the advent of cheap DSP and compute power overall movie sound tracks have gone to encoding an object, for instance a helicopter or flying bug as an object in space, and leave it up to the processor to determine which speakers that goes to.
In theory, this would allow you to have 100 surround speakers, and the processor would determine how that bug or helicopter pans around the speakers.
This is part of the reason why you now see crazy number of output channels on high end processors.
Sorry, I should clarify. In my posts above I was referring to "Dolby Surround" as used in motion picture auditoriums. For reference look up the Dolby CP 50/CP 55 processors.
For home use, the original Dolby Surround label was used for a system which did not have the full capabilities of the motion picture version. Consumer level "Dolby Surround" had a gated surround channel but no other steering if I remember correctly. When Dolby finally brought all of the motion picture goodness to home processors the consumer products were re-badged as "Dolby Pro Logic."
Consumer Dolby Surround = Motion picture Dolby Surround without the full steering capabilities
Consumer Dolby Pro-Logic = Motion picture Dolby Surround
Consumer Dolby Pro-Logic = As above, but I think it introduced better steering and a music mode. Not 100% sure.
As far as I know, "Dolby Pro Logic" was never a label used in motion picture auditoriums, it was always called "Dolby Surround"
Sorry here I meant to say Dolby Pro-Logic II
Going back to my discussion on Dolby Surround and op amps being used for the final mix downs.... when a strong surround signal was detected, that needed to be removed from the front channels. Your plane or bullets can't fly over if they are also playing through the fronts.
I've found used Q-Sys processors on ebay to be a great way to experiment with such.
For instance, it's been easy to implement any of the LCR matrices in this link..http://elias.altervista.org/html/3_speaker_matrix.html
The drag and drop method of placing components into a processing schematic allow for endless, easy to try, experimentations.
I've been thinking about this issue. What we really want is to tease out in phase from out of phase sounds between the channels. If sound is in phase and equal level in both channels at a particular frequency, it should be hard steered to the middle. But opposite phase content should be left entirely in the side channels. That's my thinking.Dolby would be ruthless in turning L and R down, while Oscar was showing that being more gentle could really let the sound track breathe and create a more immersive experience.
But what do you do when a frequency is playing in both channels that's partially out of phase? It seems to me that all three channels should play in that case. So L+R gives you the in phase portion of the signal. Half of that should be extracted from each side channel. This seems strange to me. For the left channel this results in L - .5(L+R) = .5(L-R). and right channel is R - .5(L+R) = .5(R-L). So all three channels should be playing, and it's back to what I started this thread with, a matrix of L-R, L+R, R-L, except the side channels have to be turned down by .5.
This seems to work perfectly for things that are equal volume in left and right channel regardless of phase differences. But it doesn't work when things are panned left and right by volume. If left is playing alone, then the derived mix should also only play the left channel. If left is louder than right and in phase, then only left and center should play. So it seems what I might want to do is add steering logic to the simple summing matrix.
If only everything in a 2 channel recording were either pefectly in phase, or perfectly opposite phase, this would be easy. Or, if everything were equal volume but only varied by being in phase or out of phase by various degrees, this would also be easy. When there's volume panning and sounds that are various degrees out of phase it gets complicated. Almost all recordings have various degrees of in and out of phase content between channels as well as volume panning. Darn it!
Oops! It seems there's a problem here with math ideas not being properly applied. If L is equal in volume but opposite in phase to R, they will cancel out so .5(L+R) will equal zero, so L - .5(L+R) = L - 0, which equals L! So you can't treat the L in the (L+R) as equivalent to the stand alone L and jump to .5(L-R). But .5(L+R) is correct. Hmm.... You have to do the stuff in the parenthesis first and then complete the equation.his seems strange to me. For the left channel this results in L - .5(L+R) = .5(L-R).
Well, it turns out they are equivalent. If the signals are out of phase, .5(L-R) = .5(L-(-L)) = LOops! It seems there's a problem here with math ideas not being properly applied. If L is equal in volume but opposite in phase to R, they will cancel out so .5(L+R) will equal zero, so L - .5(L+R) = L - 0, which equals L! So you can't treat the L in the (L+R) as equivalent to the stand alone L and jump to .5(L-R). But .5(L+R) is correct. Hmm.... You have to do the stuff in the parenthesis first and then complete the equation.
Algebra really works, and my sanity is restored.
So this is different than my original matrix, but this one also assumes that the side speakers are placed apart in a normal listening triangle. And, it doesn't work correctly for any signals that have a difference in level from left to right.
I've owned both of those systems. They are what got me thinking about issues of crosstalk. What really got me going was when I tried a physical barrier in front of my face and heard what that could do when reasonably well dialed in. Now I'm thinking about Blumlein's point that coincident pairs of microphones where volume panning rules will produce the correct phase response across the head for all panned positions. So we really don't want to reduce crosstalk at the ears. The problem is comb filtering for any position that isn't hard panned to one speaker or the other. So more speakers means reduced comb filtering, and a more stable off axis image.Kind of related was Bob Carver's decorrelation circuit which he claimed fixed the lack of channel separation in CDs vs. records and Polks use of inner midrange drivers out of phase with the other speaker.
I've played with Dolby up-mixing and was extremely impressed with some settings, yet also not completely satisfied that it wasn't somehow degrading the sound. I didn't perceive that effect from native multi-channel recordings, so it seemed logical to me that it was an up-mixing issue. I kept returning to unprocessed 2 speaker playback for 2 channel recordings in the end, which makes me want to get more control over exactly what is happening with the up-mixing and see if I can come up with a result I can unequivocally say I prefer to just two speakers. Plus it's a fun project. If I can figure what I think ought to happen, then I get to learn how to write software that will do it for me.
I think I know what to do for certain situations, so I have a set of specific algorithms. I just can't figure out a universal algorithm that will take all phase and level scenarios into account in a way that seems coherent to me. There's one idea I have that's super simple and will work as I think it should on all in-phase or perfectly out of phase material. On stuff that's partially out of phase it will produce distortion that will have to be filtered out. That might be good enough! I'd have to try it and listen. I fear though that it's going to destroy some subtle phasing effects in a way that's going to be less than satisfying.
OP:
Well I remind you that the matrix system for theaters was developed in large part due to the variety of listening positions in the theater. However it had a lot of challenges IMHO before I'd consider that audiophile grade. Chief among them was the inherent delay in decision making by the matrix, and the challenge of reproducing L, C and R at the same time. No matter how you sliced it you were a long long ways from the audiophile ideal of being bit-perfect.
Best,
Erik
Best,
Erik
I thought that happened automatically, as the surround information was encoded with opposite phases in both channels so that they inherently cancelled each other leaving the sound coming only from behind. And, this surround channel being delayed, did not interfere with the cancellation at the front.Going back to my discussion on Dolby Surround and op amps being used for the final mix downs.... when a strong surround signal was detected, that needed to be removed from the front channels. Your plane or bullets can't fly over if they are also playing through the fronts.
But DPL (not DPL II) definitely had an auto-balancing option according to the DPL white paper (attached) and this was mandatory during 'movie mode'. Maybe the time constants for steering were different from the professional Dolby Surround.I was referring to "Dolby Surround" as used in motion picture auditoriums.
What about LCR steering ? Were they the same ?Consumer level "Dolby Surround" had a gated surround channel but no other steering if I remember correctly. When Dolby finally brought all of the motion picture goodness to home processors the consumer products were re-badged as "Dolby Pro Logic."
@ASCTim
If you'd like to try DPL, there's a free trial version of Surcode decoder that you can try for 2 weeks or so. I think this software allows decoding to audio files (wav) that can then be played back on your system.
https://www.telosalliance.com/legacy/minnetonka-surcode-for-dolby-pro-logic-ii
https://surcode-for-dolby-pro-logic-ii.software.informer.com/3.2/
I'm not sure I understand this issue... Consider a flute left-of-centerstage playing a scale; assuming minimalist stereo-recording, the left mic will receive a series of musical tones, each tone consisting of a fundamental and multiple harmonics that are linearly-out-of-phase due to distance sound travelled, earlier in time and louder in amplitude than the similarly linearly-out-of-phase fundamental/harmonics that the right mic will receive; repeated for the whole scale (not to mention chords etc.). Miraculously, if this mess is played back with "high fidelity" our head/ears can "disassemble" the reproduced-in-room soundwave and (more or less) mistake it for the original live sound. Any effective processor/algorithm will have to preserve the myriad aforementioned relationships in amplitude, time, and linear phase (really linearly-out-of-phase).
(My analogue biamp 4-driver wall-bounce console experiment linked in msg #75. My reservation regarding reduced HF stereo separation in #77 please see below.)
Thanks, I had missed this 2023 thread. Not sure if @ASCTim has somewhat changed his assessment; there were multiple threads on related subjects (such as his "A Hafler inspired solution for the phantom center image problem"). All rather confusing to me! Good to see his (2023 above) chart that higher frequency lost stereo separation in "differential" L-R | L+R | R-L, which made perfect sense and matched what I heard.There's a good collection of information in this post.
This below, "wall-bounce dipole-differential with omni-center console", using four drivers, two amps and...
Below 1000 Hz it's mostly phase that gives us directional info. At 1500Hz it's a mix. By 2000 it's mostly level difference. You can see that the array starts to create a level difference around 1000 Hz that gets stronger for a while until it looses power, and eventually at higher frequencies actually goes backwards. This has prompted me to roll off the extreme highs on the side channels. I thought I was hearing that! My attempts at measuring were showing that reversal too.
Dolby Pro-Logic II must have been when some steering was introduced to the rear channels because I know DPL type 1 had no rear steering >Sorry here I meant to say Dolby Pro-Logic II
The rear content of type 1 was purely L-R, with the rear speakers out of phase to create a 'toy spatial effect'.
The rear of type 1 was also filtered to a bandwidth of 100Hz to 10Khz to reduce nasty artifacts coming from Stereo VHS.
- A Hafler inspired solution for the phantom center image problem
