A good way to reduce R-2R DAC linear error
I use best DAC
WM8768? why not use PCM1792/4? IMHO, Delta-Sigma DAC is not better than R-2R dac in sound quality, although its spec is better.
To Bernhard, using 4 pcm1702 for balance is enough, And to validate if only need to test 38 code for each PCM1702.
