I have the BMS 4550 with me but even that is a bit heavy apart from its good technical performance
For me, part of the excitement with this new driver is that it is relatively small, light weight and cheap, all of which play a big role in reducing costs to get one if I have get one imported from abroad (as any new good driver will take eons to reach the market here and import duties here are too high).
Then, due to its smaller size and phase plug design, makes it easier to fit into MEH design, and even normal ATH horns but horn design can be optimized without worrying about a throat extension etc.. And if all that comes with a native smooth response, sufficient high frequency extension, and lower distortion across the band, I don't know what else to ask for in a compression driver..
