Hi guys, I'll repeat my question: Is it possible to run H900 at 2 ohms using 4 pair of MJW21195/MJW21196 with 120-60-0-60-120?
What power expect?
Also, here is schematic for the guys who like challenge. That is something more then 1KW SMPS from diysmps forum, but I reformed that in two step, for H900 amp.
Cheers.
What power expect?
Cheers.
Let's go with the first question.Also, if somebody need details about building SMPS, I can help.
Where we can find the transformer?
Thimios.
Ofcourse, you must to made yourself. ETD49 core N87 so as accessories you can bay online from Mouser.
Core: B66367GX187 EPCOS | Mouser
Coil Former: B66368B1020T1 EPCOS | Mouser
Clamp: B66368A2000X EPCOS | Mouser
I don't know exactly.I received this kit from a friend and i posted it here.post2970 middle pic,
is 0.6mm diameter wire typical of 55kHz?
I would expect a thinner wire to reduce losses.
I do not know much about SMPS but I think it puts thicker wire for not have problems at high power consumption.
Regards!
Ciprian
- 900W H-class PA Amp with Limiter
