Thanks My friend I will do this rite now.
good luck my friends. U can check component layout too on pic i give to meansure any error.
Any ting wrong here on my H900?
hey waylene, i check ur b900 again and i see many wrong here, please check ur ic NE, u put wrong position. Be aware any transistor on main headsink may have isolator. Check it. I see mje 340 biases tr on middle position miss isolator. Be carefull sir.
Hello my friend!!! Thanks for all your help! I appreciated much Highly. The mje 340 transistor is a covert with it's own plastic, with out metal side at the back. I will check the ic Ne now to see what I do wrong there. But still Thanks a lot my friend.
What this that mean my friend?
it means you can install it without worry of mistake.
because the diode is twin. both legs 1 and 3 are the same. 😛😀😀
This is my email address: warren@stonethree.com Really a good and nice friend to me. I like to be in contact with you when I got problems like this. What kind of amps you build as I must ask Sir?
Ok sir, just to make sure that rite and no wrong there.
do you fix H900 now?
Greetings, please help, is there a top and bottom layout of h900 as the pictures? I want to make pcb.
thanks a lot.
seem like pic i upload. See page 274. But, maybe little different.
thanks a lot.
- 900W H-class PA Amp with Limiter
