900W H-class PA Amp with Limiter
Just want to ask! Is this the same signal connection on H900 as on B500?
I started amp with rite power supply, but no sound out of amp.
This amp (H900) nothing heat up or blow on amp, but still not got sound out of it. See attachment.
Can you send me a drawing to explain me much easier Sir? or can you show on the photo I send you, just to make it easier for me to follow. Sorry Sir, I'm just a small learner in building amps.
ok sir, no problem, but i use phone at this time, maybe later id u can wait 🙂
if not, try this, this amp same with b500, just this amp have stepper. U can check any error with b500 u have.
Hi, you can use H900 as B500 to check where is the problem.
remove IR2117 & the mosfets, then jumper the pad D-S of the mosfet(pin 2 & 3).
Power it with B500 supply on HV+ & HV-
(MV+ & MV- not use for this test)
& if it is can work,
you need to check the stepper only
Can you send me a drawing to explain me much easier Sir? or can you show on the photo I send you, just to make it easier for me to follow. Sorry Sir, I'm just a small learner in building amps.[/QUOTE
look at the pic , i make a red and black circle test point. Color i give same like multitester probe u have. I hope this will help u sir.
Regard.
