start post no. 1
greetings master apex. how can i get the schematic for h900? its pcb design, parts placement power supply section and all calibrations?
thanks and more power to post more powerful amplifiers...
Connect LED+10k resistor parallel with the MUR1620. It will be no light without signal, but it will flashing if the step driver is working.
I can give the schematic if you need it.
Sajti
hi sajti can u share the schema thanks.. its owkie i used mur1640 instead of 1620? still waiting for solution..=(
That's fine!
Sajti
thanks i will try.. my internet sucks.. i delete my previous post..=)
thanks i will try.. my internet sucks.. i delete my previous post..=)An externally hosted image should be here but it was not working when we last tested it.
hey.. Stay cool sir.. Everting will be fine and success if we cool here .
thanks guys now my h900 is working, i clean the board with lacquer thinner,and test again.. now step up is working .heres my pcb thanks apexhey.. Stay cool sir.. Everting will be fine and success if we cool here .
hey.. Nice job sir. Keep cool ok .
congrats! you got a good board with clean tinned traces...
Hi Apex,
just a question: Why didn't try the Crest step driver? It's quite simple, use just common components, and cheap.
Sajti
Tracking Down Converter (TD class) will be better, and amp will be TD2000 instead H900
Looks nice. Do You have the full schematics?
Sajti
Sajti
Yes, I will share TD2000 in 2014
Hi Mile , warm greetings from Macedonia , i have experience with audio amplifiers Can you send me the full documentation about H900 ? (power supply board , amplifier board PCB layout , circuit and so ) I want to make stereo version of H900 Also , how much toroidal transformers i will need for this amplifier ? Just for the amplifier .. 2 kW will be enough for the 2 channels ? Maximum AC voltage should be Will i get maximum power with 2x55V AC 1000VA transformer for one channel or ???
And i still don't know why 4x40VAC ??? can't be done with 2x40VAC ?
And if it is needed 4x40VAC show how to conect the power supply to the amplifier board , sure with the layout pcb
greeting daniel.
I dont know why u ask that. Everything u ask is here, please read from first page, dont be lazy..
Regards.
I put together the schematic of TD driver in the simulator, but it's was not succesful, unfortunately...
Sajti
Sajti
You must simulate full schematic.
I will do it, at least tomorrow. I had some idea, how to implement it.
Sajti
- 900W H-class PA Amp with Limiter
