good morning diyers.hi guys.=)pls check and is this correct position of ksp92 i used instead of bf421 thanks..
Hello Gantex,
That's gonna be 56.56VDC and 63.63VDc respectively.
Neil
thanks for your replay neil, is that single rail? can i use it?
if i use this apex psu class H. How much result VDC? Its same or not? I see some defferent here, please check this?
In my APEX H900 I am using 4x45V AC, and it works fine!
hello antonamp, thanks for comment. How much VDC u get if use 4x45VAC. I mean for HV and MV ?
Regards.
Venus
hi to all i need your expertice i have problem with my h900 version2 ..my High Voltage not working always in mv ,but sound good.. i used mur1640 instead of 1620 and ksp92 instead of bf421. pls check picture above. thanks..
iam not see any pic here..
see post #2664 thanks =) im still waiting for solutions....... good evening
good evening for u sir, but night for my country
even u check your ksp92 is different pinout, ksp (EBC) bf(ECB).
Sorry if im wrong..
best regard.
Sorry if im wrong..
best regard.
yes .. is this correct??
and how i know that my step voltage are working? i have only DMM thanks morning.
can u share of pic bottom layout.?
Proper connection of driver collector is to step rail.
he mean is MV. Coz driver is part of final rail. Sorry if iam wrong.
Best regard to all DiY.
Regards.
Venus
I have 125,4VDC,-62,5VDC,-0-, +62,5- ,+125,4VDC
Connect LED+10k resistor parallel with the MUR1620. It will be no light without signal, but it will flashing if the step driver is working.
I can give the schematic if you need it.
Sajti
- 900W H-class PA Amp with Limiter
