the amps looks fine, I prefer the modulated rail, over the swithed, as it makes less switching noise.
Sajti
Sajti
Greeting Apex audio, i want ask to mr.mile can i replace ic ne5532 with tl072 or jrc4558 and what the best ic can i use?
use tl072
MY H900, if i want to hear bass with a little bit high frequency what do i have to change? i test my H900 sound very good for sub speaker, i ask if use non sub speaker and want to hear a little hard bass that what i mean, thanks Mr apex for a good design
Thanks for your reply mr.mile u are the best people i never found, i apreciate and regard for u,. Thanks before.
Nice work, use active x-over for subwoofer and bass boost circuit for non sub speakers.
Hello mr.mile, iwant ask to you, sorry if iam wrong, can this vas used for vertex? If can, what can i do?
thanks for suggestion Mr. Mile, i'll search active x-over n try it, about bass boost circuit any sample suggestion that will match with this H900 n off course easy to diyNice work, use active x-over for subwoofer and bass boost circuit for non sub speakers.
@mr suryadi can i have layout for that amp? please send by email freak_or_fear@yahoo.comlittle modification
little modification
be careful with the TO-220, without proper insulation it can cause shorts.
Sent from my MyPhone A919 Duo using Tapatalk
i already used that ring isolatorfor mje13033/32 and irf540
- 900W H-class PA Amp with Limiter
