Hi, can you send me design of class h and g. My email iiee3602@yahoo.com.ph
Hi, I have several designs gyh class, my email is jluis.hp @ gmail.com
Hi, can you send me of class g and h design. thanks!
Hi everaone
I am new on this forum and I want to ask some questions.
Somebody tried to make power supply for APEX H900 with voltages 100VAC-50VAC-0-50VAC-100VAC???
I have transformer with those voltages and want to use it for this amp if it is possible.
I know that is pretty high but I just want to know if somebody tried to do this?
Hi everaone
H900TEF with add more outputs can use PSU with this voltages.
I found the old transformers with voltage 35Vac-0-35Vac and I'll use them. I have two of the same so that the power problem solved. All I care about how much power your amplifier with a voltage of 70VAC-35VAC-0V-35VAC-70VAC??? Thank you.
allow to me to try.
if transformer has 70Vac, in reality when connected to a load, this voltage will sag, let's say by 10% regulation, to 63Vac.
according to Mr Ohms, P = V*V/R, therefore
for 8 ohms load, P = 63*63 / 8 = 992W
for 4 ohms load, P = 63 * 63 / 4 = 1984W
however, Class H amp usually has efficiency of let's say 78%, therefore
for 8 ohms load, 992W * 78% = 774W
for 4 ohms load, 1984W * 78% = 1548W
(correction is welcome, if any. thanks.)
H900 TEF INQUIRY
Hello Mr. Mile... and others who is willing to help & clarify about which among these two schematics is correct. The specific question is the connection of driver C4793 & A1837 collector pin which will be the proper way to connect. Is it connected to +-HV or to +-MV. What will be the difference between these two connection if they are both correct. Hope this can be clarified so i can proceed with this project.
Many thanks & Regards
Proper connection of driver collector is to step rail.
Thank you very much Sir Mile for quick reply....
Best Regards
please be clear in Mr. Mile, whether in Voltage MV or HV?
I wanted to ask to Mr.Mile or the other could answer, even fellow DIYer may experience the same thing with this problem, .. why the H900 standard when playing a kick drum, bass disappears (PA as SUB) ... the 4R or 8R load. but if for a bass guitar no problem, voltage regulator 45ac-90ac-ct ... 4kva. and I do not use nsl 32. where is that must be repaired or is there any other damage?
sorry my bad english
thanks and regards
thanks and regards
Class H amp steep view - YouTube class H tranzistor step-up 2sc 5200 2sa1943 work very good
Looks nice!
Sajti
- 900W H-class PA Amp with Limiter
