900W H-class PA Amp with Limiter
I will try to make a 3kw smps with 6 outputs for the 3 steps class h, with pfc , the pfc it is almost complete , it's designed for 3.2 kw , effiecency is 97% an uses 3 irfp460 and it's switching frecvency is 75khz .....
All the project is for my school liecence diploma 😀
Great project for school, some engeeners with over 20years of expirience was afraid to try 3kW smps... good luck with project and diploma.
hi apexaudio
greetings do you have any input limiter circuit to share simple
one
thanking you
andrew lebon
Simple limiter without LDR or OTA
Hello to all the Amp Masters
I would like to get my feet wet in building some amps. This is a fairly new topic to me. I do find it very interesting and useful. I do however have some questions. I read through the whole thread but some of this is confusing to me.
Each board is a single channel amp? What is the difference between the A & B on the input side?
What is the difference between V1 and V2 of the amp?
Are 2 protection circuits required for 2 channels?
Is the VAS part of the amp or is it a seperate circuit?
What is a step driver? Is it also required?
I mostly hang out in the projection area. DIY and projector modding is my main hobby. I however am a DJ and have no amp for my speakers. I think it would be way more fun to build one than buy one and that led me to this thread........Thanks for the help...CHEERS!!!:cheers:
A & B pins on the input side are for bridge mode (wireing schematic is in the thread), not use for stereo.
V2 use dual comutation diode in TO220 case with 3 pins.
U need 2 protection circuits for 2 channels
VAS and step driver with IR2117 is on PCB (step driver with TL072 is for convert classAB amps like B500... to classH, not used for H900)
If U are beginner, I suggest U to build some simple amp like this:
http://www.diyaudio.com/forums/solid-state/167394-quasi-amplifier-begginers.html
