80W Hybrid Audio Amplifier!
222mVbe is still not turned on.
But is is ~ 3times higher than previous.
Are the outputs undamaged?
Output should not be demaged 🙂 I ordered them not to do so! heheh
OK
"I changed drain resistor yesterday, to 1,8R.
Now upper is 362mV, lower 367mV, source 3,3R have 622mV.
Base/emitter power transistors 222mV and 505mV."
When i "plug in" dc servo, soldier 1k resistor on opamp out. Output transistors have Vbe 379mV and 348mV, dc out near 0 or 0🙂
"current dumping" ?
I see a CCS loaded SE driver into a complementary push pull output stage, with a nonsense tempco on the driver that can never compensate for changes in output stage temperatures.
Current Dumping Technology | QUAD | the closest approach to the original sound
And that's it 🙂
With 1k there will be slightly lower gain, but OK
"current dumping" ?
If you stare at the schematic long enough it makes sense. Notice the two output paths. The IRF9530 is a CCS. The IRF530 is the current dumping transistor. These are the output devices under light load. On higher current peaks the 2SC3264 and the 2SA4302 become active due to the voltage drop across the two 1.5R source resistors on the mosfets.
How does one increase the number of output pairs in this design, in order to make it capable of 4 ohms loads and/or higher rails voltages? Is it done the usual way, i.e. by providing current balancing emitter resistors? Is this possible at all?
Best regards!
And Hi again, little update, i have a little time on sunday.
With this config i have:
More current on IRF, resistors 2.8R, and 2x 1.8R. Look at negative half of sinus.
Update
I was sure that there is low current to drive output transistors.
Increasing resistors between irf to 2ohm, mekes better sin wave, and square wave doesn't have overshoot. I think i will increase it to 2,2 ohm and leave i that way.
