737 Max
Also, it's always worth mentioning the immense scale of these engines -
attachment.php
attachment.php
attachment.php
Thanks for the photos, they really give a good idea of ​​the size of both models. Six seats could go into the turbine of the 777 ...😱
And how many would go into the turbine of a discontinued Jumbo 747?
Was it wise to stop making that high-capacity model instead of updating it? It did not have the sophistication of a MCAS system (failed) like the 737 Max but, the pilots had control of the machine, and not the machine over them....🙄
I agree, some do. Amazing aviators!!
I also fly out of Denver professionally and have for 25yr. Never seen a bird that high, unless near a Mountian, and not all that far above the terrain. Where the United engine had the problem was over the city and ~7000' about the terrain.
Having said all that about birds flying at altitude I do think it it highly unlikely to experience bird strike at those heights. Birds and especially birds of prey have incredible eye sight* and most likely give a large flying object a lot of space. I suspect bird strike mostly occurs because birds are getting sucked into to the engine because they cannot anticipate the enormous suction jet engines create.
*Vultures fly at those heights to increase their field of vision on the ground in the search for food. Hawks and eagles can spot a mouse from a mile away, vultures are just looking for large carcasses.
" fly-by-wire " ?
Explain to this ignorant, please. What does that phrase mean, translated would be "wired flight", you know, my poor English
My take (and a few guess) on this is:
Starting era of flying: Used organic and later metallic wire to force a change of appendices from the cockpit (flaps, rudders etc).
Then mid (?) 21:st hydraulic system controlled the appendices (flaps etc) - hydraulic valves etc close to controls in cockpit.
And finally electrical wires sending only control signals manipulating either hydraulic or electrical controls situated close to what is in need to be altered (flaps etc) - this is todays "fly by wire".
OK?
