6V6 line preamp
Joined 2009
Salas, just curious how do you calculate the resistor value of 2R7 between the LM317 & the filaments?
Hey Salas, do you still like the Maida regulator PSU for these? I'm currently working on PCBs for power supplies and was thinking of putting one together as a spiritual companion to the other boards.
I'm also putting together a simple mosfet ripple filter PSU on a 50x50mm PCB as well since it's what I use in 75% of my own builds, same basic circuit as the one Pete Millet used in his Engineer's Amplifier, but just with a diode bridge-
It would be easy to start with this and expand it to 50x100mm to work in an LM317T to make a Maida regulator board.
diyAudio Chief Moderator
Joined 2002
But looking the simplicity I will make your design.
Voltage source mode heater PSU as you already got has the characteristics of coming up instantly and maintaining fixed voltage to all tubes if you roll a lot.
CCS mode is minimalist, occupies less space, comes up soft. But various tubes can develop different Vh. Depends on exactly made filament for nominal spec current. You are happy if within 6.1V-6.5V range. Else you tweak Rset.
