OK, I will look out for them. Do you have a specific circuit for either of them?
Experiment, and thou shall be happy.
![wizard :wiz: :wiz:](https://files.diyaudio.com/forums/images/smilies/wizard.gif)
It should be around 1 mA with 10V plate to cathode and 0V screen grid bias.
http://www.radiolamp.su/pdf/127/5/5964.pdf
I've built the 5687 pre, and have been running it off a 12v battery between a Virtue Piano CDP and a Virtue Sensation amp. The Piano has quite a high output and I needed to attenuate it to avoid distortion.
But the results are very encouraging, clearly bettering a commercial tube pre-amplifier kit!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hi guys
Just a tube noob here, what is the final schematic for 5687, I'm just a little lost.
Also what are the resistor wattages.
I like the idea of low voltage and the cost should be cheaper compared to the other only tube project I have done.
Any information on anything tubes ect... will be greatly appreciated......
Robert
https://audiokarma.org/forums/index.php?threads/1626-preamp-build.931276/
Robert
I was referring to the low voltage version.Use a bunch of diodes and 220uf 50v caps to make 50 plus volts from 12v ac
You could also use a 5va torroid to get 130v B+
- Tubes / Valves
- 6SL7 or 6SL7GT for broken Tubalizer
