I was wondering if anyone has a data sheet for a 6240G vacuum tube? A Japanese manufactured tube used in Luxman Amps back
in the day.
If no one has a spec sheet, I am looking for whatever information I can obtain. Absolute maximum plate voltage, maximum working voltage,
typical plate voltage used in the Luxman 3045 amp, Mu, Gm, Plate Curves etc?
Cheers
Pos
in the day.
Cheers
Pos
Bottom of the last page. https://www.museum.uec.ac.jp/archive/tube/(010L) Rating of Japanese Receiving Tubes.pdf
Google is literally worthless anymore until you start wrapping quotes around terms.
in the day.
Cheers
Pos
I wonder if it is not a similar tube to the 12BH7, or maybe 6FQ7/6CG7 ?
T
I just did some searching around, and it looks like a 6CG7 is a suggested replacement.
Kinda, but some of the voltage ratings are different.
In the searching around, I also found an Ebay seller asking a fairly hideous price for a used pair of 6240Gs, with no guarantee that they actually worked. This, folks, is why I design and build my own amps, with stuff that I know that I can get.
Not sure of the 6240G pin-out (base=m9-03??) but a substitute looks do-able with some juggling:I just did some searching around, and it looks like a 6CG7 is a suggested replacement.
- If the gain is important and the the 6240G is handling input under 2VRMS, then I'd be tempted to try the 5670 at maybe Vak=200V, ia=7mA, Vgk=-4V
- If the 6240G is handling big input signals >2VRMS, then the 6CG7 has lower gain but offers at least as much headroom at maybe Vak=200V, ia=9mA and Vgk=-6V
6240G | mu=35 | gm=3.5mS | Vak=200V | Vgk=-5V | ia=7mA | heater=600mA | base=m9-03 (??) |
6CG7 | mu=20 | gm=2.6mS | Vak=250V | Vgk=-8V | ia=9mA | heater=600mA | base=9AJ |
5670 | mu=35 | gm=5.5mS | Vak=150V | Vgk=-2V | ia=8mA | heater=350mA | base=8CJ |
Same pin-out as the 6CG7, so could try plug-n-play to see how it works
However, the electrical characteristics are more like a high rp version of the 5670 than a high mu version of the 6CG7 ....
- Tubes / Valves
- 6240G Data Sheet
