6240G Data Sheet
I was wondering if anyone has a data sheet for a 6240G vacuum tube? A Japanese manufactured tube used in Luxman Amps back
in the day.
If no one has a spec sheet, I am looking for whatever information I can obtain. Absolute maximum plate voltage, maximum working voltage,
typical plate voltage used in the Luxman 3045 amp, Mu, Gm, Plate Curves etc?
Cheers
Pos
in the day.
Cheers
Pos
I wonder if it is not a similar tube to the 12BH7, or maybe 6FQ7/6CG7 ?
T
In the searching around, I also found an Ebay seller asking a fairly hideous price for a used pair of 6240Gs, with no guarantee that they actually worked. This, folks, is why I design and build my own amps, with stuff that I know that I can get.
I just did some searching around, and it looks like a 6CG7 is a suggested replacement.
Not sure of the 6240G pin-out (base=m9-03??) but a substitute looks do-able with some juggling:
  • If the gain is important and the the 6240G is handling input under 2VRMS, then I'd be tempted to try the 5670 at maybe Vak=200V, ia=7mA, Vgk=-4V
  • If the 6240G is handling big input signals >2VRMS, then the 6CG7 has lower gain but offers at least as much headroom at maybe Vak=200V, ia=9mA and Vgk=-6V
6240Gmu=35gm=3.5mSVak=200VVgk=-5Via=7mAheater=600mAbase=m9-03 (??)
6CG7mu=20gm=2.6mSVak=250VVgk=-8Via=9mAheater=600mAbase=9AJ
5670mu=35gm=5.5mSVak=150VVgk=-2Via=8mAheater=350mAbase=8CJ
Reactions: astouffer
Reactions: bondini
