500W PA amplifier with Limiter
APEX audio B500 with signal,clip,power indicator.
I would like to thank mr Mile, this amp sounds very good.I also use a balance input with a separate regulator, the sound is clear.😎:violin::sax::cheers:
thk.
regards,,, Arif Sumadireja Paris Van Java
yes it's true B600, I already fix. The PA is functioning properly, but a lot of components that I replace the transistor BC can not be used when using the PA transistor BC the negative rail will not work, continue to flow on out sp. after, transistors BC, I replace the use of type, 2N5401 & 5551 PA can work, there is another component, I, replace pada.resistor 3k3, I, replace the 680 and 560R resistors, I, replace. 150R and VR, I, ganti.1k. Nothing is left to the transistor MPSA42 & 92, I, using 2N5401 and 5551. sorry, english, my, not good. only, that's all I did on the B600
Dear nano nano
I want to ask you. Did you mean you changed bias resistor 3K3 with 680R and 560R in serial? And 150R with 1K resistor (without VR)? Can you share the measurement how much voltage bias did you get with that replacement?
Pcb b500 scp,signal,clip,power indicator.
may be useful .. pcb B500 scp (signal, clip, power indicator) already tested ok ... thank Apex Audio ..
