500W PA amplifier with Limiter
hi apex sir,
to check can i use this regulated power supply with 56v ac,10a,after rectify 83vdc. any changes?
Hi, everyone.
I want to design and make amplifier that can push 3 speakers par channel. I used PA300 schematic to draw PCB, and add some more output transistors.
Apex, AndrewT and others who want too help, can you plaese look PCB and suggest me if there is something that I need to ADD,REMOVE or CHANGE VALUE before making PCB, so amplifier can work normal. Thanks.
