Well only if you listen to MSM misinformation (Meant to have you live like they want you living) ..... If you do the research yourself you will see ANY OS is OK if you have it configured rightshakeshuck said:If you mean using it to browse the web, it's not recommended from a security point of view. Neither is 98 or XP.
Sure, like if you don't connect it to the internet.
If you use a modern browser on an old OS, and some modern anti-nasty software, and you're behind a firewalled router, you stand a chance. A lot of the up-to-date browsers don't support the old OSes, unfortunately.
Your chances are greater if you're not browsing using the admin account, of course - which most people sadly do.
> 3) D Base III
I believe you are stretching.
But seriously: my most-CPU-time program in the house is WINSOLIT from 1992. Made for Win3, runs fine on XP.
The end of MSPaint:
Microsoft Paint’s Days May Be Numbered - The New York Times
- Member Areas
- The Lounge
- 5 Most Used Applications
