41Hz AMP2 upgrade?
@MikeHunt79:
The limiting value/component is the driver chip (TP2350B) which is designed to drive MOSFETs with a maximum Qg of "just" 120nC.
If you wanna use 8 output trannies per channel, be sure the total Qg is not very much above the 120nC (... divided by 4 makes 30nC max. for each MOSFET) otherwise you might fry the driver chip (a "large" heatsink is highly recommended in this case - i.e. see picture of 'theAnonymous1').
It's more likely to find MOSFETs with a small Qg having only small Vds ratings. So it's possible to drive 2 ohm loads with the "disadvantage" of a lower power supply value, hence a lower maximum output power.
Maybe you can find the "magical" MOSFET with a very low Qg, high Vds, low Ron, ... 😉
Besides finding the right MOSFET you have to change the over-current limiting resistor(s) to allow for higher currents to the 2 ohm load.
The board itself, without any modifications, isn't really prepared to handle such a high current application. However I recommend in this case to 'strengthen' the tracks by using litz wire soldered on the high current paths just above the corresponding tracks.
:dead: Actually I wouldn't spend to much time in designing a new PCB because Tripath went bankrupt and was bought by Cirrus Logic for just 3.25 million US-$ (if I'm not mistaken - quite a bargain though). As long as nobody knows that Cirrus is continuing to produce Tripath chips I wouldn't continue with any (re)designs/modifications based on (former) Tripath chips. Even the homepage of Tripath is shut down. So, do yourself a favour and don't stick with Tripath chip(s). My feeling is that these chips are dead and only available from distributors as long as their stock lasts. :dead:
You could try the FDP3651U 80A FETs I put in my RB-TDA2500 board. They are only rated at 100v so you would have to use a lower supply voltage, but they should be able handle a 2 ohm load with no problems.
The tracks of the AMP2 are puny compared to the RB-TDA2500 so I would be careful trying to squeeze too much current out of it. You would at least need to bulk up the high current paths like Corax suggested.
EDIT: If you take a look at the data sheet for the TA0102A there is a "TEST/APPLICATION CIRCUIT" on page 5 that shows the high current paths. I know this is a diffferent IC, but it gives you a general idea of where the current is flowing.
http://www.ortodoxism.ro/datasheets/Tripath/mXyzxwxq.pdf
@MotoMan_Yz400:
This might help. It's the reference board design from Tripath for the TK2350 chipset - TC2001 (modulator) and TP2350B (driver).
The bottom side:
The potential of these amps seem like the first thing to break in your home stereo system would be the speakers or your electrical breaker in your home! :bigeyes: I love it!
Remember there is time to enjoy music, and there are times where you just want your ears bleeding :devilr:
Hi
Good news, after some problems... I was able to get 273w on bench with 11.59v @ CT and 94.7 on output...
Then in car, first with 50Hz tone, 11.0v input of smps, which is 0.5m away from CT, connected with 20mm^2, output of smps should be 93v, amp was just before clip I think, so about 270w sinewave on 240w rated sub 🙄
Then with car on, output voltage was pretty much dead solid at 126v, volume was pretty high and I was :bigeyes:. At that point I stoped because I was afraid I would burn speaker, or break panels of my car or something like that...
There was ~7C in car, so was smps and amp, no heat what so ever, just output inductors of both channel and chip (driver), and they had about say 20C
Now I think is time to finish case, and make other circuits for it...I want to see the power of bridge 😀
