2SK1530+2SJ201
Does it not bother you at all that the amp might have sounded better with correctly matched devices?
not one bit
Im happy if it sounds good 🙂
If not, why buy matched devices at all🙂
like I said, it helps to ensure they are genuine 😉
besides, apart from a standard F5, I also plan to use them in multiples for a classAB, and the matching is needed 😉
Matching FETs
... use Idss matched K170/J74 even if Papa clearly says that they have to be Yfs matched.
Within a FET family and probably within a type of construction, it appears that Idss, Yfs & Voff are well correlated.
I don't have much experience matching MOSFETs but I do with small signal JFETs used in mikes ... the 2n54xx & u3xx range
You certainly see this in the datasheets. If Idss is matched, it is likely that Yfs in the sensible current range is matched and so will Voff
____________________
Anyone have a pointer to EKV models for these MOSFETs?
