> Does anyone have any experience with this vendors mosfets?
They don't even define what is meant by matched.
At what temperature ?
Single point or curve traced ?
Over what current range ?
To what tolerance ?
NNPP match or just NN-PP match ?
As already extensively published, all the above have a significant factor on matching and especially on matching yield.
> ..unless you are able to find two more pairs of those type 1 transistors, of course.
I don't think anyone else can / will provide those for you (tight NNPP match under working conditions).
You might, at best, get single point match at room temperature.
Just my 2 cents,
Patrick
To what tolerance ?
Just my 2 cents,
Patrick
I was not trying to be funny - just to help
If you need Vgs matched N and P devices you might also check what member Blues or Zhoufang have left.
Not really the same thing, but certainly genuine devices.
Just trying to be funny myself!
I know the matching might not be optimal, but I´m out to buy regular devices for my f5 first of all. NicMac brough up the matching.
I´ll send blues a pm.
Is that really so? No effect on distortion whatsoever?The F5 uses a single pair of N & P, these do not need to be matched N to P.
A stereo set requires two pair, these do not need to be matched, neither N to P, nor N to N or P to P.
Certainly, a channel mismatch may/will lead to channel imbalance. No?
Of course this might be corrected by moving one speaker 5 cm
please, lets not confuse the poor man more than 'need be'
for a standard F5 only the input jfets 'needs' to be well matched
but wont hurt to use matched outputs as well
if any channel 'imbalance', most likely it will be much more affected by any other source in your setup
that said, Im buying a few off NicMac's sets ...could be last chance to get any good ones
Only EUVL seems to care that they are matched for both.
balanced amps
actually, I think Nelson said the output N to P matching would be more or less pointless since everything changes once mounted in amp
though I may remember wrong
btw, some time ago i asked Spencer if he could match some J74 to the matched K170 quads I got from him at some time before that
very accurate specs were written on them
his reply...he said he could, but that it would most likely change a bit since they would be matched at different time of the year, and at different 'conditions'
so...not simple at all....but I got them anyway
Not simple at all. But if you know the pitfalls also not that difficultso...not simple at all....but I got them anyway
BTW Idss matched I presume
Nope. I don't think so. Actually the opposite, if my memory does not fail.
I think EUVL recently showed in this forum the consequences of a MOSFET N-P Vgs offset in a F5 versus F5X. Much worse in the F5.......
not everyone have their own professional lab to verify the quality of their F5 amps
if you really want to go that far as you suggest, I think you will need a professionnal lab/workshop to verfy that every amp actually works that well
and to really get there, my guess is you will have to build many amps(modules), and match them all in function
dont know, I only have the idss specs
but I trust Spencer
Im happy if they work, and keep working
my crazy 'audiophile' days are over
its just a crazy hobby now
and probably until ...
Does it not bother you at all that the amp might have sounded better with correctly matched devices?Im happy if they work, and keep working
If not, why buy matched devices at all
- Design & Build
- Parts
- 2SK1530+2SJ201
