Merlin,
Have you tried LL2745 for your 26 preamp?
With 5.6:1 step down, lower output impedence will better match with your low impedence AVC.
Cheah
No, I haven't tried. I used the TVCs with SS mono amps (Erno Borbely "Millenium" 75W RMS Class A) so I didn't used tube amps (can match better, but I don't know).
hi Felipe,
1. The scope pictures are input and output?
2. If the gain is not correct, maybe the transformer is not wired the way you intended. If you need help with the wiring, you must give us a link to the exact model of transformer you have, and draw exactly how the transformer has been connected. With Lundahl, it's more complicated than with other maker's parts.
If the vertical (Voltage) scale on the scope pics is the same for In & Out, Then it looks nearly 2x gain.
Does it sound good?
Yes is the same vertical scale voltage, yes looks near 2x gain but when I no connect the 26 and only use the TVC sounds louder....checked the TVC and there is no gain 1x
Felipe, you will get more help with amplifiers if you install a program to draw schematics.
You can use LTspice, if you don't want anything better. It runs on Windows (any version), and even better, it is designed for WINE, so any Linux PC, or even Mac can use it.
It takes only a few minutes to learn the schematic interface. And you can use triode, pentode and DHT symbols.
You can take a Screenshot of the schematic, and post it here.
With no schematic, it is very hard to give you definite help.
other ways of drawing schematic:
DIPTRACE (excellent) or Eagle (widely used) PCB design packages.
They have free versions for non-profit use.
If you have a tube with 6dB amplification and connect an opt 4.5:1 you will devalve the voltage of the signal with more then half. Do we agree on that?
mu of the 26 is 8
Debug in same way as any amplifier.
Measure all dc voltages.
Measure Anode current. Measure filament current.
Use scope to see ac waveform on grid, anode, and output.
1st scope pic AC waveform on grid, 2nd scope pic AC waveform on anode & 3rd pic AC waveform on output. Also pic with schematic with measurements. Of course all pics and measurements are of the right channel where is no gain.
- Tubes / Valves
- #26 pre amp
