And R1, 100 k grid leak resistor is there, measures 100 k and goes between grid pin and ground?
I have 100K pot, isn't enough?
Put one there and measure between grid pin and ground. Pot Wiper to ground or Grid Pin to ground, doesnt matter.
What happended? Why did anode voltage go up to 175? Whats the value between pin 1 and 3, grid and cathode?
Aha, so you need a fixed grid-leak. Shall we tru to go down to 150 V on the anode and measure current again then?
nonono, with adjusting the last filter R and a proper fixed grid leak resistor to hold grid to ground
Wich value for the last filter R, grid leak resistor I have 110k and 12wich one?
What is your value now? If 4750 add like 2 k to that. You know the procedure now.
Grid leak is ok any.
Your circuit works fine now. Don't change anything except for the B+, which needs to be lower so that you measure 140-150V on the plate.
Thanks Iko.
We are closing up. Try 10 k. My PSUD from yesterday said 16k but I dont know if I had all your data right.
- Tubes / Valves
- #26 pre amp
