Your schematic looks to have a 229V transformer with a choke input. If you look at your simulation, it shows 202V at C3, if I am not mistaken. Is C1 value as shown?
I use a similar arrangement with 220V transformer with choke input and I have around 190V before the regulator.
Are you sure?
Are you sure?
C1 is a Russian teflon FT-3 01,uF 600V
Only different is I have between the tx and the AZ1 100R
And put somewhere a resistor in series - like 10R - in the power supply to calculate current draw. Just to be sure that tubes are working.
Why do you have a 100R between the transformer and the AZ1? Normally you want the lowest output impedance you can get.
Attached schematic how I wired the Lundhals LL1660, help will welcome?
I don't know if it matters, but I think you have the outputs the wrong way round on the LL1660. Plus should go to plus.
To protect AZ1 maybe. But where do you see it?
An anodefollower inverts.
What is the last 2,7k/100nF for?
told me Rod Coleman
2K7 to low the voltage 100nF not used
If you have 306 something B+ you must have put something larger as the first cap then 100 nF. Check that, or remove it as earlyer said. Then you need a cap after the 2,7k. 100 uF:is I would say worx.
What is the voltage drop on the 2,7K?
I have removed the CCS+Gyrator, I guess I need a dummy load in place of Gyrator and tube to measure, wich value?
1rst 100nF removed, I don't have 100uF I have 220uF could I use after the 2K7?
for 300 V 5 mA 60k
for 250 V 5 mA 50k
for 200 V 5 mA 40k
for 150 V 5 mA 30k
Yes you can.
Update your simulation on PSUD with the new data. Calculate 6mA current draw for the tube. You will find the correct resistor value.
Put what Stajo suggested as a start value. You will have to get around 150v on your load.
Using 2k7 for R1 changing last cap for 220uF with a dummy load of 30k psud gives 229V?
- Tubes / Valves
- #26 pre amp
