1st issue digital CD releases vs streamed/downloaded later re-issues
I've put together WAV or MP3 recordings of the same thing whatever you want to play it on, of Uncompressed v Compressed immediately following each other.
Definitely the compressed version sounds duller, but the bass seems to be up. The graphic may give a hint with higher peaks and all that.
The curse of getting into higher and higher quality sound, which I am getting into, is that the difference in quality of recordings - even mp3 files - becomes painfully apparent, and I ma desperately working the EQ to get me something sounding good.
When you see a "Digitally Re-mastered" label does it make you nervous?
Why EQ? Have you measured a frequency response problem you think EQ can fix?
If your system sounds muddy, its likely not an EQ problem. However sometimes muddy sound can be subjectively improved some by putting a parametric notch filter right around 300Hz. Adjust Q and depth for best sound.
