13v + Lm3875 = ?
Will this work?
post 21 works.
it needs a 15+15Vac 2A transformer (60VA), but this will not power a chipamp particularly well. Peak current ability is lacking.
post 22 works. But look at the ripple, 1Vpp, for an output current of 0.1A. Again this cannot run a chipamp.
Just go and buy the correct transformer. If you are patient you may pick up a bargain.
I don't want to push my own stuff, but I am not makeing a profit, so I guess it can be forgiven. Follw the link below my post and look for the Universal PSU in the catalog. It is about $9.99, allready have the components silkscreened, so you just have to populate it.
These boards are from the DX amp groupbuy, I had some extras made.... This will give you all the regulation you need based on a C-L-C filter and can accept caps up to 35mm in diameter.. well 37 if you don't mind them very close... Pads are finnished in Sterling silver.
