100W Ultimate Fidelity Amplifier
The days work. Got this far with my A40, alongside are my NX14's
Do any of the MJE's need to be on heatsinks?
just transistors wich are in line with output transistors should be on same heatsink.
you should use 2sa 2sc driver transistors as assigned on schematic - I tried to use mj1503x drivers and amplifier tended to go to thermal runaway. with 2sa 2sc drivers all was right.
besides me,you are the first person I know that uses that board. good luck,have a fun!
yes,I have acomodated it from two boards that Olaf has draw for A14 and A33. Olaf did a great job there,and it was very easy to chop those two into A38 board,since it has two output pairs instead three. A40 has input stage from A33 and output stage from A14,with a little adjustment-take a look at A14 and A33 schematic.
it sounded just as A40 on AlexMM board. just use all transistors as they are assigned at schematic.
there were a few simple modes. Mile advised to use 2 of 22p at B-C of driver transistors (easy and best to soldier directly under pcb,althouhg for me it worked without them).
there were few schematics with mistakes.
first one was 470r marked instead 470k wich actually should be,connected to middle pin od 4k7 offset trimmer. there was no burning with 470r but it was very difficult to adjust offset.
another thing is a slight difference between schematics of A33 and A40,there is one less 22r resistor connected to GND.
also,if you have 100p at input,iz was advised to change it to 470pF - it will work either way but it will pick up less "noise" with an open output.
i have assigned all of those diferences at pictures under.
Thanx for all the info. I didnt even know about the two bridge wires marked A and B. I will be sure to make the changes as per your recomendation
make a twisted pair,not too loose and also no need to over-do it. just make sure to connect them as short as you can. I believe that it is not too much problem to leave 22r,but it is not a problem to put short-cut instead. just be careful that you have all right connections according to schematic. picture of pcb in my previous post was the latest I have in sprint6,after I made my pcb.
