100W Ultimate Fidelity Amplifier
ax30
Hello, I would like to ask about these source connections, are they independent of each one or what their connection would be like. I did not find more information in the post of this design
Hi, in this PCB they are independente, in reality you dont need fuses on VAS circuit, but they are the same. But in some cases, the VAS circuit may be feeded with higher volts than the power circuits.
no , you can not use 24V.
Here is a simple fan control by Mr. Nelson Pass.
It can be scaled for 24V also. Its constant speed and speed control by trimmer position. Cant get simpler than this.
regards
prasi
thank you prasi, IRFZ44 ok in that?
edit: oh that cannot work with heat. i want fan work when amp need it. like a 70C or i dont know maybe more? for now i just connect directly to F100 PSU
