Hello Apex.What power supply do you suggest in using with MM3 and MM4 phono preamps? One based on LM317-337 or something else like the ones below,series PSU, shunt PSU ?
And PCB. 🙂
NOT TESTED
wow! superman, a pcb in less than 2 hours! hats off!
Go to A-class Preamp PSU
Is safe +/- 42Vcc in AX11?
Thanks.
Yes, but with 8 ohms load only, regards
Not really. About 4 hours. 🙂wow! superman, a pcb in less than 2 hours! hats off!
We talked about this scheme in another forum.
A40 factory PCB
A40 in progres , have to solder, some transistors on boards and will be ready soon . Prototype was tested successfully 🙂
Alex
Alex
Yes, but the PCB from the picture is 2-layer. 🙂Hi,
Files are in post #4145
SX9 bottom layer
Hi Milan,
Please post bottom layer.
Hi Milan,
is this from a personal message?
I'm talking about the bottom layer of the pbc; not the bottom you're thinking about....
- 100W Ultimate Fidelity Amplifier
