Pins 2 & 6 are the -IN pins.
Pin2 has R16 and R19 connected. These should be on very short traces to -IN.
Pin6 is unused.
Connect this channel to sit at half way between supplies.
I'm not sure about C3 & R7, maybe someone else can advise.
But C3 should maybe swapped with R7, so that the resistor is next to -IN.
Pin6 is unused.
it is my favorite hobby of all
If it is so,make a pcb for this amplifier protection🙂
yes thimios I was looking at the new schematic 🙂 I'm also working with another PCB with DC and 3 sec delay this one is not completed I still checking for errors I will see if I can find time to make this new protect 😉
Juan
http://www.diyaudio.com//www.pinterest.com/pin/create/extension/
Very nice work!yes thimios I was looking at the new schematic 🙂 I'm also working with another PCB with DC and 3 sec delay this one is not completed I still checking for errors I will see if I can find time to make this new protect 😉
Juan
Do any of the transistors need a heatsink? Also, what is the ac voltage?
No need to use heatsink, AC is voltage from main transformer 2x30~50vac
OK, I reworked it and changed the IC to TL071. Hopefully this one is better.
Nice work, you can short SGND and GND
The 0v reference for the opamp (D4 & D5 junction) is connected to the output as per the cct. I'm curious how it works.
Sent from my HUAWEI MT7-L09 using Tapatalk
Here is a quick idea for layout of the protection PCB. It can be improved further based on suggestion of Mr. Mile or someone else😀. Meanwhile I will keep on making it pretty😉.
reg
prasi.
reg
prasi.
is already pretty brother 🙂
Juan
Mr prasi,
Sources must be connected and drains are switching gnd to spk ground, not drain to source.
Hi
I completed building the AX-14 amplifier and i am getting 4vdc output on AX14 what could be wrong with it
My voltage is +/-20vdc.
please tell what is wrong
Is your input GND connected to star GND?Hi
Yes, it's stereo.
Schematic from mister Mile http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-550.html#post4518802
Sprint layout file for own customizations attached
Oh, i see now i skipped 100K resistor from 5551 colector to +, sorry about that
Need seggudtion psu...
You can use this simple PSU
Yes, it's stereo.
Nice work, thank you
- 100W Ultimate Fidelity Amplifier
