Double check there is no continuity from the case of the to-3 and the chassis. I had a devil of a time when screwing them to the L bracket.
I had to sand the surfaces around the drill holes a lot to keep the outputs isolated.
I am using silpads.
I will double check that. What I did was fitting a heat shrink tube to the screws, n that had been checked for couple times before I turn the power on, but no harm to check one more time.
hi. i am looking for the schematic and pcb files of AX14P with DC and overload protect on pcb.can anyone help me?
http://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-155.html
Post# 1547 & 1565
thanks a lot!!
It's up running
Amp was running stable at 15mV for about an hour last night. It drifted a bit but can easily adjust them back to 15mV after 20 minutes. Temperature on my heatsink was only 28C. I thought I could run them a bit hotter so to test the sound is better or.....
There were -15mV and -9.5mV at output. Don't know if I have to make any correction to this issue.
Have to put up a protector, so I could taste the good sound.
Congrats! DC at your outputs are acceptable, I even have 50mV on mine and it's fine.
So, what did you do to solve your bias problem?
I parallel a 50k trimmer to the 4k7.
I see, so so you opted to adjust the emitter-base resistor, instead of the base-collector. trimmer should be set at maximum resistance value initially, and lower the value to increase the bias current. but be careful not to adjust the trimmer to zero.
setting trimmer in series with 1k or 1k5 resistor is much safer in practice but not so easy to do than setting it in parallel.
I thought the other way. It's safer to parallel with a fixed resistor in case the trimmer open.
In quest of bass
Hi all,
I have been listening to my AX11 mk2 for two days with no less then 10 hours. As said by the other members and all claimed that this design produces really good bass, but I don't have this feeling with my build. This is to compare all amps that I have of which include 6c33c otl, 6c33c se, Moskido and 807pp. I don't know if I have done anything wrong. I build this with the pcb posted at #2201 with BC546b instead of 2N5551, all other parts are same on that pcb. Power supply is Mur860 to 10,000uf to 33ohm wrapped with 40 turn 1mm wire as coil to another 10,000uf so to make the total of 20,000uf on each of + and - 35v rail.
Albert
Hi all,
Albert
For PSU is it 33 or 0.33? Hopefully 0.33...Hi all,
Albert
I am using 3x0.47 in parallel between the caps. Mine are also 10,000 uF x2 per rail.
What are your emitter resistors? I am using Fukushima mpc
What type of cap are you using for the 10uF input cap? I am using nichicon UFG or UKW I forget....both are audio grade.
Hey Carl,
They are 33 ohm,but only 0.46 ohm after parallel with the 40 round coil. I copied from the smymsyn thread. If this is the devil I can replace them with wire.
The 10uf input caps are blackgate monsite.
Albert
Hey Carl,
Albert
Ok good...I would crank the bias up as high as you feel comfortable and let it break in. Which outputs did you use?
They are running at 60mv since day one n I only found 33c at heatsink after 4 hours. I will crank them up to 100mv after I regroup my psu by taking out the 33 ohm / coil with a wire. Or do you think it better to put a big resistor there ?.
Do you mean the output transistors? TO-3 MJ15003/4. All my speakers are 8 ohms.
- 100W Ultimate Fidelity Amplifier
