1000W PA Quasi NMOS Amp - Class H Stepdriver possibile ?
pcb
HI khalsa
thanks for reply hope it works out pcb almost finished
warm regards
andrew lebon
THANK YOU for teaching me
Hi Irvynejay
greetings thanks for advice of track thickness and i am grateful to you for teaching me how to use pcb software pcb is complete with step on pcb
i will send u pcb layout for more suggestion i need software to make lay file to pdf to upload pcb
warm regards
andrew lebon
How about this ?
look here......
Attachment: Quasi NMOS CLASS H PA and HI-FI amp
Class H Stepdriver without ICs... more cost effective design and devices easy to get.
Fort BJT lovers:
Mosfets can replace with 6 x 2 SC5200 but mosfets are more rugged and can driving harder compare to BJTs
Soundquality is proved from fuzzly diy Audio people and hard to beat from the deep lows to clear highs
Amp with N Mosfets or BJT Output stage in Class AB configuration is build, tested and proved for stable working with high qudio quality from hundreds DIYer
Attention: People dont claim with me because
Class H Stepdrivers not tested will do it next weeks
Hi nmos have you ever tried this amp or do you have a link to the forum of the discussion of this amp posted ?
  • NMOS Balanced CLASS H Schematic.pdf
