Global Negative Feedback in KT88 PP amp question
I am in the process of testing the attached KT88/6550 PP amp; however, I am not really clear about how can you tell the feedback is actually negative or positive before you actually apply and play with the feedback network. Here is the thing that confused me: From what I read from text book or searching through the web "Negative feedback occurs when the feedback signal is 180 degrees out of phase with the input signal, effectively reducing the overall gain of the amplifier. Positive feedback, on the other hand, occurs when the feedback signal is in phase with the input signal, amplifying the input and potentially leading to instability"
However, from LTSpice simulation it's opposite to what it said. Simulation indicated that both Input and Output signal are on the same phase for the feedback to work. The attached files showed the actual KT88 that I am currently testing with snap shot of input (Vin) and output (Vout) are out of phase for now.
Can I go ahead and apply the global feedback network or I need to swap the wirings for Vout to be in phase with Vin?
I just wanted to make sure since I don't want to ruin a brand new output transformer. Thanks in advance.
Not sure if I understand your question/problem correctly. But perhaps the following is of use.
The first stage in your schematic operates with cathode bias. So, the cathode voltage is positive with respect to the control grid (and as a logical consequense, the control grid voltage is negative with respect to the cathode).
Now imagine part of an input signal on the control grid going upward/positive.
This will cause the voltage difference between the cathode and the control grid to decrease.
So, for feedback applied over (part) of the (not bypassed!) resistance in the cathode lead to have a negative (so, 'input signal opposing,) effect, it has to also go positive, since it has to counteract the decreasing voltage difference between cathode and control grid.
Just to prevent a possible misunderstanding: Of course this effect will only be negative (so 'input signal opposing) as long as the amount of feedback stays below the amount of input signal.
But comparing the mid-frequency input and output waveforms in your schematic's topology,
the output signal polarity (not "phase") should be the same as the input,
if the feedback resistor goes to the top of the 75R input stage cathode resistor.
So reverse the connections just after the second stage, either before or after the 0.18uF coupling capacitors.
The polarity also depends on how the output transformer is internally connected, and how it is wired into the circuit.
You may require additional compensation to prevent oscillation at high frequencies, more correction than just
the 200pF capacitor which is connected across the 1150R feedback resistor.
Reactions: flex2
Since you have a Mullard-style topology (voltage amp to long-tail pair phase splitter), IMO you have the phase-splitter connections to the output tubes reversed. Here's a classic Mullard arranged in correct phase for negative feedback:
Of course, the output transformer primaries could also need to be changed, but since currently your input and output are out of phase, you're going to get positive feedback if you hook it up as is.
Reactions: rayma and lcsaszar
That is entirely possible. The important point is that to be negative feedback, the output decreases when the feedback increases, ie it works to lower the gain. You have a choice of where to pick off the feedback signal and where to apply it so that this works correct. The relationship between input and output phase is not directly of importance, although it does influence your options as to connection of the feedback loop.
Jan
The reason for your confusion about feedback and reverse polarity is due to the fact (and someone please correct me if I'm wrong) that the feedback in this instance is applied to the cathode of the input stage. If I hook up one of my Williamson amps to a scope, the input signal and the output signal are in phase with each other, so I'm getting negative feedback. In your case the scope shot shows a reversal of phase, which will produce positive feedback.
I think I have that right! ;-)
Figure 31: Basic schema for global negative feedback.
Global negative feedback is obtained by feeding the attenuated output signal back to the cathode of the input stage vacuum tube. If the output signal and the input signal have the same phase, the first is subtracted from the second, reducing distortions in the amplified signal. The voltage divider composed of the resistors R1 and R2 has the effect of attenuating the output voltage used as feedback. The capacitor Csn forms, with resistor R1, a step network to adjust the feedback signal phase to guarantee stability.
Reactions: rayma
The old problem with phase on either output tranny primary/secondary connections. If the secondaries are the tapped type then the connections on primary side may have to be reversed.......my amp test for this is to set signal source into the mV region, disconnect the GNFB so one gets a reasonable output into dummy loat, note it; then attach a 47K-100K resistor to the GNFB to the output and observe if the output voltage actually rises or decreases. It´s the decrease one is after, then go ahead and connect the correct value. Too low a value resistor (47K-100K) will increase towards positive feedback, into oscillation.
Le bench baron
Yeah, this process has always been done empirically, meaning you try it one way and if it wirks right great if it doesn't then you got it in backwards (out of phase) and you simply switch which tube each end of the primary connects to.
If you blow up an output transformer doing this then your output transformer was inadequate for the job anyways.
often times the lead outs are mislabeled anyhow and you've got to be able to work through it and end up with a functional amplifier..
You won't blow up an output transformer, but could blow a speaker if you have one connected...
Grid is an inverting input, cathode is a non-inverting input. There is no real standard for transformer primary-secondary polarity, but as mentioned, it can be measured with a dual trace scope (both channels triggered from same input). You might have to swap drivers to have the output polarity correct (0 Ohm tap grounded)
Thanks for all the inputs.
I finally rewired the output tubes and transformer wiring to make the output to be the same phase as input just like I have in simulation. I liked the idea of Le bench baron and temporarily connected the 50K to the global feedback to see if the output decreases. It worked as expected and now I know for sure that I have a global negative feedback loop. I just finished making measurement on the input/out voltage versus frequency without GNFB. Very clean sine wave from 30 hz to 20khz. Soft clip started on bottom curve with input about 100mV (peak).
Now the next fun part will be figure out the correct GNFB and compensation network for the amp. I have been playing with LTspice and plan using it as a starting point but would appreciate your expert inputs on your methodology and practical approach especially using test equipment for measurement and analysis to come up with correct feedback and compensation network.
Inputs are greatly appreciated.
What tubes are you using for the input and phase-splitter stages? What is the output transformer?
Basically, you'll want to determine the open-loop gain, and then decide how much feedback you want to (or can) apply. 20dB would be standard but people seem to use less feedback nowadays. A lot depends on how much feedback your OPT will tolerate. I'd be prepared to set up a 10kHz square wave at 1 watt, then gradually increase the feedback and make sure the waveform holds and the amp doesn't start to oscillate. Check for ringing and overshoot. If you can achieve the desired amount of feedback, then you can work on taming and ringing or overshoot and getting the amp as stable as you can.
