Babelfish F8
One channel running….
Reactions: birdbox
I took a break after getting one channel running. Sounds very good on the Radio Shack Minimus 7 shop speaker, which is a speaker I have listened to for 35+ years. If it sounds good on that speaker it’ll sound great in the main rig.
I’ve got Iq at ~1.5A and with the 3U is all the idle current I want. I will run squares and distortion measurements at some point…..
Reactions: tonyEE and birdbox
I don’t know if the BC556
Babelfish F8 isn't that much different to Papa's original F8, entire FE is practically one 2SJ74BL, while BC556 is nothing more (nor less) than cascode for 2SJ, bringing its pentodish transfer function even more pentodish, yadayada
anyhow, what you hear is sum of all details, major one being feedback arrangement - low impedance network tightly controlling JFet's source
and, HF performance better than expected, taking in account that I opted for IRFP150 (plenty of capacitance)
what I did differently (vs. Pa's) is not much - dual rails and fully DC coupled, JFet drain loading ensuring use of broad range of JFet Idss without change of OLG, Iq setting from just warm to hot (by personal preference)
Reactions: Russellc
That’s exactly what I’m hearing, more pentode-like than I’ve ever heard from Toshiba fe and IR FETs. I’m very used to the sound of both jfet and BJT in the fe but never together, however little it may be contributing, the BjT cascoded device MIGHT be doing great things here. it’s a very, very good fe and the HF performance is stunning: there’s depth to this performance that is just remarkable. We aren’t getting single notes but harmonics that decay on either side of the fundamental. I’ve personally never heard this from JFETs, whether SE or P-P, but they are in general lower noise than BJTs.
It’s a brilliant design, whatever is happening. Definitely pentode-ish.
Reactions: chakija
and, now, Babelfish F8b and Babelfish F8m are singing practically the same
go figure
all pentodish parts, ending with THD Sprectra of regular SET amp
there are so many myths and legends in this area of fun, it demands years just to shed them all, ending with clean awareness that informed choice is one ring to rule them all
:clown:
Reactions: ggetzoff
